ball joints.
Old Aug 21, 2008 | 06:20 PM
thanh4o8's Avatar
Default ball joints.
does 94-97 integra ball joints fit 98-01? upper ball joints
also how can i tell when i need new ball joints?
Modified by thanh4o8 at 7:45 PM 8/21/2008
Old Aug 21, 2008 | 07:05 PM
t-splice.mn's Avatar
Default Re: ball joints. (thanh4o8)
i am pretty sure that they are the same for all 94-01 tegs, don't quote me tho, a part store could tell you for sure tho. the only ones i have found available are adjustable. otherwise you can get the whole upper control arm with ball joint..... its much easier that way.
to check it, lift the front end off the ground, grab the wheel at 12 and 6 (top and bottom) and push in and out, if it moves and you can see it moving, then it needs to be replaced
Old Aug 21, 2008 | 08:05 PM
thanh4o8's Avatar
Default Re: ball joints. (t-splice.mn)
when i turn left and hit this one sweet spot there is poping noises. would that be also the problem?
Old Aug 21, 2008 | 09:13 PM
i guess its possible, it would have to be really worn out if you can hear it tho... that noise could be caused by worn out stuts too.
Old Aug 21, 2008 | 09:16 PM
Chicago_Type_R's Avatar
Make sure u lift it by the frame . not by the LCA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t-splice.mn &raquo;</TD></TR><TR><TD CLASS="quote">
to check it, lift the front end off the ground, grab the wheel at 12 and 6 (top and bottom) and push in and out, if it moves and you can see it moving, then it needs to be replaced</TD></TR></TABLE>
If it has a lot alot of play Replace them quick because U don't want the ball joint popping out of the steering knuckle.. if the ball joint pops all i can say it a OUCCCCCHHH
Old Aug 22, 2008 | 12:43 AM
thanh4o8's Avatar
Default Re: ball joints. (Chicago_Type_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chicago_Type_R &raquo;</TD></TR><TR><TD CLASS="quote">Make sure u lift it by the frame . not by the LCA.
If it has a lot alot of play Replace them quick because U don't want the ball joint popping out of the steering knuckle.. if the ball joint pops all i can say it a OUCCCCCHHH</TD></TR></TABLE>
i will check them for sure tommorow
CARMA_626
Suspension & Brakes
Jun 19, 2008 05:25 PM
90CivicDaily
Jun 4, 2008 04:39 PM
MyDragCar
Dec 2, 2004 09:58 PM
2ndgentegracer
Aug 30, 2004 02:31 PM
blackEF
Jun 27, 2002 09:23 AM
