Balljoint replacement
Old Aug 29, 2004 | 10:57 PM
2ndgentegracer's Avatar
Default Balljoint replacement
I need to know if the guy at Advanced Auto was correct in saying that all four front ball joints are the same. I only bought two for now incase they are different. I drive a 1992 Integra GS if that helps. Thanks in advance.
Old Aug 29, 2004 | 11:03 PM
IVI's Avatar
IVI
Default Re: Balljoint replacement (2ndgentegracer)
of course theyre not.
lower ball joints are diffrent from the upper.
i dont think the upper can be replaced you must get the whole arm.
lowers can be pressed in and out.
Old Aug 30, 2004 | 11:21 AM
Default Re: Balljoint replacement (IVI)
Is it okay if i just replace the lower ball joints then. My dad said i would need to replace the tops also. Is it okay if i only replace the bottoms?
Old Aug 30, 2004 | 11:45 AM
IVI's Avatar
IVI
yes it is okay.
ive replaced both of mine since my right one broke.
its extremely dangerous to have one break while your driving especially across a turn or at highway speeds. you will end up losing control of the vehicle.
if you take it to a shop its about 100 dollars per ball joint including parts and labor.
once you get ball joints done you should get an alignment.
Old Aug 30, 2004 | 12:02 PM
Code Blue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">yes it is okay.
solid advice
Old Aug 30, 2004 | 02:31 PM
Default Re: Balljoint replacement (Code Blue)
Cool thanks for the advice. I just did not want to have to buy the whole arm assembly. Already got the lower ball joints ordered.
NMJimCRV
Honda CR-V & Element
Oct 13, 2014 08:30 PM
themtn
Honda Civic (2001 - 2005)
Mar 26, 2010 03:01 PM
Ron454321
Oct 2, 2009 04:18 PM
G2_Fella
24
Jun 16, 2009 03:20 PM
90CivicDaily
Jun 4, 2008 04:39 PM
