Ball joint question
Old Jun 18, 2003 | 10:00 AM
SMC Integra's Avatar
Default Ball joint question
My passenger side ball joint won't tighten back up. The nut gets about half way and then the entire joint starts spinning with the nut.
Any ideas on how to keep the joint from spinning or do i have to replace the entire thing?
Old Jun 18, 2003 | 01:52 PM
g2 GS-Argh's Avatar
Default Re: Ball joint question (SMC Rice Rocket)
You've got to put a lot of pressure on the joint. What I've found to be most effective is to take a pair of channelocks and squeeze the top of the tie rod end to the socket. I know it's a pain in the ***, but just apply a lot of pressure and be patient. HTH
Old Jun 18, 2003 | 01:56 PM
jaM3s Bond's Avatar
Default Re: Ball joint question (g2 GS-Argh)
Jack up the LCA with a FLOOR jack then tighten away.
Old Jun 18, 2003 | 04:01 PM
IN VTEC's Avatar
Default Re: Ball joint question (X EneMy X)
Sometimes I have to do both of the above to get the nut all the way up.
Old Jun 18, 2003 | 06:58 PM
Default Re: Ball joint question (IN VTEC)
thanks guys ill try it tomarrow
Old Jun 18, 2003 | 07:03 PM
TwankyDC2's Avatar
you guys have any idea a lower ball joint on a gen3 integra would run for? at a junkyard?
Old Jun 18, 2003 | 07:28 PM
hybridreams's Avatar
Default Re: (TwankyDC2)
I think it's only about $30 or so brand new from Pep Boys. Might want to check that out instead of getting a used one from the junkyard.
CARMA_626
Feb 22, 2009 06:48 AM
EJ8 Kenobi
Suspension & Brakes
14
Jul 19, 2007 09:48 PM
M15
Jan 19, 2007 02:44 PM
FlyZlow
29
Mar 3, 2006 10:51 AM
robbin
Feb 24, 2003 10:16 AM
