Ball joint
Old Oct 22, 2010 | 07:27 PM
98tegLSvtec's Avatar
Default Ball joint
hey everyone thinkin i may have a ball joint that needs replacement, what are the signs of a bad ball joint?
Old Oct 22, 2010 | 07:30 PM
Spawne32's Avatar
Default Re: Ball joint
if it pops out of the joint easily, or is very very loose
Old Oct 22, 2010 | 07:47 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If it's an upper or lower ball joint, it will probably make popping noises when you turn the steering wheel while the car is stopped.
Old Oct 22, 2010 | 08:19 PM
sounds like the symptoms.also when i hit a bump it feels like the right wheels super bounce and like loose, if that makes sense, it sounds like the wheels gonna fall right off, and the car also is pretty jurky off the start, and again manily the right wheel. and when i go over 70mph the right wheel also start to make a humming like sound,
any ideas in addition to ball joint?
Old Oct 22, 2010 | 08:20 PM
Spawne32's Avatar
thats because the wheel is gona fall off lol personal recommendation, get a set of ball joints uppper and lower (usually you replace the whole upper arm) and a set of wheel bearings for the front, have them pressed in the spindle and a shop, and bolt it back up to the car, that should help.
Old Oct 23, 2010 | 06:34 AM
fcm's Avatar
fcm
Old Fart
What Spawne32 said, make sure you do both sides, 94
Old Oct 23, 2010 | 12:38 PM
so there basically all balljoint related problems? and how much do you think all this will run me price wise? both ball joints on each side and wheel bearings on both as well?
Old Oct 23, 2010 | 12:39 PM
and where should i order the parts from? autozon or ik ebay has like a whole kit with everything
Old Oct 23, 2010 | 12:53 PM
Spawne32's Avatar
http://rockauto.com/
raybestos, mevotech, dorman
your problem sounds very ball joint related, shouldnt be too pricey to refresh the front end to where its safe, bearings are about 40 a piece, from arms are about 40, and the ball joints should be 20 a side.
Old Oct 23, 2010 | 01:57 PM
thedivineguy's Avatar
not too bad to replace either
Old Oct 23, 2010 | 04:05 PM
mocchiuto's Avatar
Hello:
You can jack your car up in the air preferably by the front sub frame and then try to move the wheel in question, back and forth or in and out to check for any looseness. You can also use something to pry under the wheel, between the wheel and the ground and pry up to see if it is loose in that manner. You will need a ball joint press to the lower ball joint or a good strong vise and sometimes the vise is not enough. Honda/Acura sells the proper adapter but depending on the tools you have available you may be able to get by with some sockets. I had the left front lower ball joint break on me on the highway at 75 MPH in my 1990 4 door! I was able to safely slide the car off to the shoulder but it did body damage to the rocker panel and the fender and tire when the wheel cocked sideways and was shoved into the wheel well, the tire had a hole burned through it. I did not catch the loose joint because the stem broke not the joint.
Good Luck
Old Oct 23, 2010 | 08:19 PM
thats around a good $200 and ill be good?
Old Oct 23, 2010 | 08:21 PM
Originally Posted by mocchiuto
Hello:
Good Luck
Im assuming your for warning me to not let this go for to long....lol
Old Oct 24, 2010 | 10:06 AM
Spawne32's Avatar
If its to the point where the joints are popping out literally from their seat, then yes you are in serious trouble, it can snap or fall out at random letting your whole wheel go the completely opposite direction that you want it to go. Just remember the lower ball joints are press in, so you either have to have a press available, or have to take it to a shop and pay someone to press them in/out.
Old Oct 24, 2010 | 10:08 AM
Spawne32's Avatar
Old Oct 24, 2010 | 10:26 AM
mocchiuto's Avatar
Right even if you just do one side for now.
Old Oct 24, 2010 | 11:57 AM
Thanks for all that, but today oriellys had two lower ball joints so i picked them up alonf with the tools to do it
Old Oct 24, 2010 | 12:01 PM
the for warning is highly appreciated, I have to drive about 70 miles between today and tomarrow, and as long as I can make it home safely ill be able to work on it tomarow night. I was able to get two ball joints, and the two tools used in the process, The ball joint "press" / C clamp tool, and a special tool for hondas especially, How long is this going to take me?
AP14TW
Jan 11, 2011 08:01 PM
moz92
Suspension & Brakes
Nov 5, 2007 01:19 PM
ke98248
Oct 23, 2007 12:10 PM
trianglegreg
Nov 15, 2006 05:01 PM
95gsr
Jan 11, 2002 12:35 PM
