Bad starter?
Old Sep 25, 2005 | 07:10 AM
Baron55's Avatar
Default Bad starter?
My battery is fine, but last night after messing with my alarm and putting everything back together; the alarm was working fine. Now the car would not start; I have to push start it and once i got it started; i drove around for a bit last night. Then took it home, turned it of and it wont start. So is this a starter problem?
Old Sep 25, 2005 | 07:11 AM
Backk InTheDA's Avatar
I hate everything
Default Re: Bad starter? (Baron55)
Well what happens when you turn the key, does it make any noise?
Old Sep 25, 2005 | 07:52 AM
Yambor's Avatar
Default Re: Bad starter? (BuilttB18C5)
sounds like a wiring problem if that circuit somehow gets wired into your alarm, like the starter solenoid wire
Old Sep 25, 2005 | 07:53 AM
I hate everything
Default Re: Bad starter? (JH4DC4-2GSR)
Yeah, that happened to my bro when he had a cut off to his starter, well i think it was to his starter.
Old Sep 25, 2005 | 08:33 AM
Baron55's Avatar
No there is no noise when i turn the key
Old Sep 25, 2005 | 08:37 AM
I hate everything
Default Re: (Baron55)
Does it sounds like its cranking, because if it is, thats your starter.
Old Sep 25, 2005 | 08:50 AM
Baron55's Avatar
no, no cranking either
Old Sep 25, 2005 | 08:53 AM
1997GS-R's Avatar
check the wire that plugs into the starter from the wire harness. this exact same thing happened to me the other day. somehow the wire that plugs into the starter had wiggled itself loose. i plugged it back in and problem solved.
Old Sep 25, 2005 | 08:56 AM
Baron55's Avatar
OK one thing....I dont know **** about these damn wires...Which wire are you talking about? Any diagrams or pics?
Old Sep 25, 2005 | 09:07 AM
1997GS-R's Avatar
just look at the starter itself...there should be a wire that is wrapped in black that is plugged into the starter...if it's not plugged in you will see it hanging right where the starter is....trust me, you'll notice a wire that looks like it should be plugged in to something...just go out there and look real quick
the end of the starter that is the furthest from the transmission is where the wire should be plugged into...
pic of starter...
the wire that i am talking about is covered up by the grommet in that pic..the wire comes out of that grommet and plugs into the starter...
Old Sep 25, 2005 | 09:12 AM
gsr dood's Avatar
check yooo ignition fuse!!!!! i burned mine out once putin in a system.
Old Sep 25, 2005 | 01:02 PM
Baron55's Avatar
Well i check the fuses that deal with ignition in the car and inside the engine bay and they are fine..Still no starting, i have to push start...the starter cables are fine too...
Old Sep 25, 2005 | 04:13 PM
Baron55's Avatar
so how much do starter typically go for? New and used?
Old Sep 25, 2005 | 04:19 PM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
check your positive battery ground wire. follow it to the starter and mess with the connection. i just bought a new starter for my ITR and it was like $240 including the core charge. im gonna take it back, because the starter is most likely not your problem. its most likely a loose ground or something with the battery cables (either corroded or bad conncetion)
oh yeah, corrosion can be anywhere on the wires even if they look clean. replace or clean those and see what happens. much cheaper than buying a starter
Mars401
Nov 14, 2016 02:16 PM
old-sk0ol
May 12, 2010 12:41 AM
tomu06
16
Mar 30, 2006 01:10 PM
mtber
Jul 14, 2004 09:02 AM
crx1856
Aug 20, 2003 10:24 PM
