Bad speed sensor need help replacing
Old Apr 7, 2007 | 07:15 AM
motormike40's Avatar
Default Bad speed sensor need help replacing
I drive a 94 gsr with a b20 with a gsr head, and my speed sensor went out. Where is it located so I can swap em out. Thanks.
Old Apr 7, 2007 | 08:56 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Bad speed sensor need help replacing (motormike40)
The VSS is located on the back of the transmission near the engine block.
The ABS wheel sensors are located at each wheel.
Old Apr 7, 2007 | 09:07 AM
nahledge's Avatar
Default Re: Bad speed sensor need help replacing (Dogginator)
As the pic shows the speed sensor is located near the back of the tranny. The side that is closest to the firewall. It's held on by a 10mm bolt i believe. Remove the bolt and pull it out. Word of advice, don't over tighten it, they tend to break sometimes.
Old Apr 7, 2007 | 10:26 AM
Thanks I appreciate the help.
Old Apr 7, 2007 | 01:22 PM
Just for other people that are going to do this.. I was told that a new DC one was going to be crazy expensive, so I went to the junk yard and pulled one off an EJ2, It bolts up and works fine, it just looks different.
streetracerjoey210
11
Jul 24, 2016 08:02 AM
jonyi27
Nov 9, 2012 04:28 PM
StraightCivic
May 20, 2006 06:58 PM
dohcdelsol
Jun 4, 2004 03:45 PM
Aeka GSR
Jan 20, 2003 03:31 PM
