Bad distributor???
Old Dec 15, 2011 | 02:20 PM
b20vteclsintegra's Avatar
Default Bad distributor???
So I have a 95 integra gsr with a lsvtec in it. Its giving me a lot of problems and im trying to fix it. First off if I give it more then %50 throttle and bogs down and shakes a little bit and sets at 3K but if I baby the throttle it goes up just fine in the rps. 2nd thing is if I turn the key sometimes it does nothing and then if I try again it will fire up. 3rd thing is surg in idle. And 4th thing is the wires that go to the dizzy look like this. I didnt do this it was think this when I bought the car. I hope someone on here can help me out
Old Dec 15, 2011 | 10:17 PM
mouab18c1's Avatar
Default Re: Bad distributor???
Those wires have been resoldered and shrink wrapped.
Are there any CELs? Have you checked all your ground wires?
Old Dec 16, 2011 | 08:14 AM
No cells checked all the ground wires they are all good. I even just took my cap and rotor off and checked them. There was a little bit of stuff in the bottom of the cap but nothing big. But I did notice something different in the coil spring there was a pack of blue corrosion in the middle of the spring I dont know if thats normal or not. But I took the icm out and had it tested at autozone and it tested ok. So im really getting lost on this. Oh and I put everything back togther and I turned the key it took a couple of sec to get any spark but then started fine. But still has the problems....
Old Dec 16, 2011 | 08:25 AM
lunalink's Avatar
that look like like really shitty soldering :lol:
are you sure thats the correct distributor? try borrowing a buddy's and test it
Old Dec 16, 2011 | 09:53 AM
mouab18c1's Avatar
Corrosion is never good. Did you just eyeball the grounds or actually took them off and cleaned them?
Old Dec 16, 2011 | 12:11 PM
There is nothing to clean on the grounds they are already clean. And yes its the right dizzy. And a closer look they are not soldering they are but connected with electrical tape around them
Old Dec 16, 2011 | 01:39 PM
lunalink's Avatar
please solder them and wrap them up with heat shrink.
Old Dec 16, 2011 | 11:00 PM
mouab18c1's Avatar
Some look soldered. The other looks like connectors. Both those plugs are going to the distributor.
Old Dec 17, 2011 | 06:04 AM
HondaPartsHero's Avatar
Technical Hero
http://www.team-integra.net/forum/bl...eshooting.html
Old Dec 19, 2011 | 06:58 AM
so I just checked something out from what I found out the coil is bad and now my check egine light just came on and its my o2......
MinimusMaximus
Apr 24, 2015 02:58 AM
DamnThatsRexy
May 26, 2013 10:02 AM
monalisa overdrive
Apr 19, 2004 09:07 PM
mattymatt
Feb 23, 2004 04:57 AM
Casey
Jul 28, 2003 02:15 PM
