bad bad noise
Old 05-27-2004, 06:18 PM
RallyRedGT-V6's Avatar
Default bad bad noise
i installed my header recently, and the holes for the header hanger bracket didnt line up perfectly, so i unbolted it, installed the header, and then was only able to put one bolt back onto the car...
now its making a terrible metal on metal scraping sound at low throttle...and its been getting progressively worse...only if im barely touching the gas though...as soon as i step on it a bit it goes away...and when im cruising at like 30, and the throttle is barely down...it makes it too
could this be anything else besides a header hanger? i dont have jackstands anymore [my roomate from college has them, when i put the header on] so i cant just jack it up on my puny little jack and crawl under there and poke around...
if it is...can i get away without that bracket? or should i take the time to take it off, dremel it a bit, and bolt it back on?
Old 05-28-2004, 03:48 AM
Default Re: bad bad noise (96integra)
anyone?
mugenracer
03-19-2005 11:09 AM
1slow_si
04-24-2004 05:58 PM
i3luemrld
02-03-2004 11:25 AM
Gen5lude
07-20-2003 02:28 AM
geminis2k
04-15-2003 05:59 PM
Quick Reply: bad bad noise
