B20V problem
Old Feb 21, 2014 | 01:36 PM
theycallmedj's Avatar
Default B20V problem
B20 with a GSR Head (B18C1) it had a really high steady rev, found a really bad vacuum leak in the intake manifold and throttle body gaskets, and a loose timing belt(but ran ok- no weird sounds), so i took the head off, and put on a new timing belt, tensioner, head gasket, intake mani gasket, throttle body gasket, torqued everything down with arp head studs, and hooked everything back up (think i have all the hoses right) and now the the high rev is a little high, but less than before and now theres a ticking or tapping sound. Ive checked the timing 2 times, and adjusted the valves and still nothing better, im out of ideas, wondering if some one could think of something maybe i missed.
Thanks.
Old Feb 21, 2014 | 03:23 PM
kaycee_00's Avatar
Default Re: B20V problem
The ticking sound might be from the injectors. As for the high idle, what rpm is the car at?
Old Feb 21, 2014 | 03:29 PM
B_Swapped93's Avatar
Sticky LMA's ! ppl always over look that skunk2 sells them for like 80$ my 550cc grams don't make any noise is that an OEM thing ?, I can't remember my old ones doing it either. I did end up having to replace the LMA's issue fixed.
Old Feb 21, 2014 | 03:36 PM
totally forgot about LMAs, ill check them to see if theyre sticking and if they are ill see about that, the idle was at 3.5 before now its at around 2 grand, and so if the injectors are making noise then there bad right?
Old Feb 21, 2014 | 03:50 PM
my injectors never made noise before, my friends did on his turbo, but thats cuz he was maxing them out before he upgraded his injectors and im not, i doubt its my injectors, but if the lmas dont fix the sound ill look into those, thanks for the replys, ill keep you updated in a week or so when they come in
Old Mar 4, 2014 | 04:01 PM
noise is gone, thanks, it was the LMA's
onlinmrine
Feb 10, 2022 12:17 PM
Cole Peters
Sep 28, 2015 05:53 PM
DustinPennington
Apr 22, 2008 02:44 PM
95ludeSE_bottle
Apr 6, 2008 11:09 AM
jayc6677
Dec 26, 2007 07:28 AM
