b20 in a teg
Old May 16, 2002 | 08:08 PM
PHaT ls-s's Avatar
Default b20 in a teg
has anyone tryed this set up? also what does it weigh?
Old May 16, 2002 | 10:08 PM
threatcon13's Avatar
New User
Default Re: b20 in a teg (PHaT ls-s)
many people have done this utilizing a crv block w/ a vtec head. go to crvtec.com for specifics.
Old May 17, 2002 | 02:39 AM
GZR4DR's Avatar
Default Re: b20 in a teg (ALLMOTORDC2)
Have one in my teg, daily driven. Very fast motor. Weighs exactly the same as an LS/vtec. Block is identical to an LS block except it has bigger bore and a vtec oil pump.
Old May 17, 2002 | 05:17 PM
PHaT ls-s's Avatar
Default Re: b20 in a teg (GZR4DR)
I am not looking for a ls/vtec or crv/vtec set up I just want the crv motor it self .Thanks anyways guys.
Old May 17, 2002 | 05:20 PM
LOwrestling2001's Avatar
umm...a CRV motor in ur car would make u slower, why the hell would u do that?
Old May 17, 2002 | 05:40 PM
voltronR34's Avatar
Default Re: b20 in a teg (LOwrestling2001)
What makes you think that motor would be slower? You must have missed his member name. One has to assume he has an LS integra. A b20 would make the car faster then.
Old May 17, 2002 | 05:44 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: b20 in a teg (voltronR34)
Type: "b20" into the search tool.. everything you need to know is in there.. damn i think they even have how to install the engine in there... Try the search before asking questions.. then if you cant find the answer.. then you post!
Old May 17, 2002 | 08:19 PM
ILOVEGIRLS's Avatar
i saw that youre from sd. do you pass smog with the b20?
Old May 19, 2002 | 09:59 AM
MyIntegra2Fast's Avatar
just finished my b20/vtec motor...b20bottom with a b16a head with type r internals and type r intake manifold..can't wait to put it in..and see what it runs..
Old May 19, 2002 | 12:33 PM
rodimus's Avatar
Default Re: b20 in a teg (ILOVEGIRLS)
exactly my question.
my guess is he might have the "hook up" for smog..
but once you take it to a state ref! uh-oh..
Old May 19, 2002 | 01:50 PM
Ri5e's Avatar
Default Re: b20 in a teg (EVOL)
To tell you the truth, if you put a B20 in an LS, you won't notice much of a difference. And if you put it in a GSR, your gonna be downgrading.
However, if you TURBO the B20, then...thats a WHOLE DIFFERENT STORY!! I'm running a B20 turbo in my Integra, and with just 8 lbs of boost, I can smoke tires in 3rd.
Old May 19, 2002 | 03:01 PM
Project SSAP1's Avatar
u dont u jsut stroke ur LS block....
85mm golden eagle sleeves
Eagle 95mm crank
Probe rods
Je custom pistons
balance bottom end
with a nice vtec head setup would kick *** all over the place
and get a better tranny
like a gsr or a itr tranny with ats FD...can we say traction????
emoticon
Sep 28, 2008 04:33 PM
wesley_925
Feb 22, 2008 05:57 AM
DA9B20VTEC
Sep 15, 2007 04:20 PM
angelSIR-G
Dec 21, 2005 03:15 PM
TwistedHatch
Aug 17, 2003 06:54 PM
