B20 INTO Integra
Old May 29, 2007 | 10:12 AM
rEnZ94tEgGy's Avatar
Default B20 INTO Integra
i just bought a jdm b20 motor for 400 bucks, do i use my same ecu or should i buy a different ecu, if yes, which one should i get...
Old May 29, 2007 | 10:50 AM
ziggz501's Avatar
Default Re: B20 INTO Integra (rEnZ94tEgGy)
run the ecu that the b20 is supposed to use. it depends what year it is, cuz there are different b20's.
Old May 29, 2007 | 11:14 AM
its a 98 crv...
Old May 29, 2007 | 11:18 AM
ziggz501's Avatar
Default Re: (rEnZ94tEgGy)
then make sure u get the ecu from a 96 - 98, cuz the 99+ have different compression ratios. u can prolly find one in a junk yard, ebay, or maybe the marketplace here.
Old May 29, 2007 | 11:23 AM
alright good looking out bro
Old May 29, 2007 | 12:06 PM
mike5809's Avatar
I think your supposed to use your stock teg ecu, when we swapped a b20 to my friends teg im 100% sure we used the ls ecu. The CRVs were automatic and your using ls injectors and wiring harness and dist so no reason why not to use the LS ecu. Also redline im assuming is lower on the b20 ecu as well.
Old May 29, 2007 | 12:32 PM
oh i see, sounds good...good lookin foo
jose19811981
Jun 7, 2017 01:34 AM
seehad79
Jan 14, 2010 03:51 PM
troppop
Jul 30, 2006 04:04 AM
B18PoweredCivic
Mar 14, 2005 09:13 AM
