b18c1 and b18c2 whats the diff????
ARE YOU SURE? Never heard of a B18C2 on the domestic or japanese market and none of my Acura books say anything about a C2 engine, just C1 & C5. Id check again. Did you look on the block @ the engine code ?
Yeah im posative it was stamped right there on the block.
Sidenote: we raced and with both close to the same mods and from a rolling start he walked away like it was no contest!?!
b18c2, as found in New Zealand/Australia area
94-99 Honda Integra VTi-R
~168hp (converted from given 125kW)
most likely rated at 170hp if converted
[Modified by HKxBlur, 12:52 AM 10/24/2001]
the plot thickens, my engnine says b18c12
what does it all mean?!?!
whoops, I think it was some bird **** that looked like a 2.
nm
[Modified by samagon, 4:54 PM 10/23/2001]
nm
Australia also get's the rare B18C7, R. spec B18
Same as the B18C5, jsut a different code for destination country clarification I guess
hondas gay sometimes.. why do they always make friggin 30 versions of the same thing.. and call every car 3 different names in every other country? Just stick to the god damn game plan Honda! *Bitch Slaps Honda*
grrr.. i fkd up
I knew GSi/VTi-R, thought it was some sort of optional engine, when in fact it's set up just like out here with the B1 and C1.. sorry about that
Its the ECU. I believe OBDI is 90-95 and OBDII is 96-00 if I remember correctly?. I think?
OBDI uses less sensors, particularly the O2. OBDI has one O2 sensor on the down pipe. While OBDII uses 2 sensors. One on the down pipe, and one in the converter. Thus making complications with test pipe.
stockegsix
Jun 24, 2003 10:27 AM
