b18C itr or ls vtec b18b w itr head
Old 09-02-2012, 07:04 PM
jdmscene87's Avatar
Default b18C itr or ls vtec b18b w itr head
i have a 2000 integra LS that im looking to drop a swap in
can i get some advice, any thoughts, or recommendations.
not sure if i should go w my original plan of piecing together my ITR b18c motor, or putting together a simple ls vtec w a built itr head and stage 2 cams.
my plan was to DD my integra while being able to track it on the weekends and really get the rpms up there to 8-9k
as far as suspension goes im pretty much done with all that,
any advice on what motor setup would be best would be greatly appreciated
i will post some pictures up asap
itr head pnp by alaniz @ ericks racing, supertech springs, retainers, valves. stage 2 cams, bwr cam gears, itr intake manifold, aem fuel rail, skunk2 tb, zerg gasket set, rc 750 injectors, itr dizzy, cr header smog legal.
Old 09-02-2012, 07:20 PM
racebum's Avatar
Default Re: b18C itr or ls vtec b18b w itr head
no brainer, get the stock itr swap. you will have 28-30mpg and oe reliability. i've had a couple over the years and as long as you buy from a place that compression tests everything you're good to go.
these build projects always have you tinkering with and fixing something
the stock itr you just change the timing belt, get new wires, plugs, cap/rotor, pcv and a seal or two if needed and run it.
i put 75k on one of my jdm itr swaps without wrenching on ****...would have gone longer if i didn't turbo it and crack a piston. the itr engine after that i left stock, drove about 2500 miles and sold the car. engine was pristine
sell your bucket of parts and get a factory motor
Old 09-02-2012, 07:33 PM
jdmscene87's Avatar
i couldnt disagree with you.. but im looking to get past the 200hp of the itr.. rite now i have a zero mileage ITR Block that i bought a few months back from HMO. Honda Motors Online.
and i have this freshly built itr head, dont know weather to finish the itr motor with what i have or build something different..
your advice is greatly appreciated..
Old 09-02-2012, 07:42 PM
816d16 owes me money!
usdm420's Avatar
Put the ITR motor together that you already have and roll with it.
Old 09-02-2012, 07:46 PM
jdmscene87's Avatar
thank you sir, i believe that will be the best choice and the easiest route since i have everything already.
thank you very much
Old 09-02-2012, 07:56 PM
mangogsr's Avatar
IMAGE#1 c
IMAGE#2
IMAGE#3
IMAGE#4
i might be doing a swap sometime in the future. just wondering what you paid for the itr head.
Posted from Honda-tech.com App for Android
Old 09-02-2012, 08:12 PM
racebum's Avatar
if you have it all...meh, assemble and run
Old 09-02-2012, 08:33 PM
jdmscene87's Avatar
i actually got the head for free from a friend who was moving out of the states.
i did my research and i found out that the head was port and polished by Ericks Racing-Alaniz w 1100.00 + in port work as well as brand new supertech valves,retainers, and springs. as well as stage 2 cams.
you can find a good ITR head w stock port and polish for give or take 900.00 complete minus dizzy, intake mani, exhaust mani..
i believe HMO may have a ITR head for sale
jdmscene87's Avatar
that will be the plan..
thanks for your advice sir
Old 09-03-2012, 02:30 AM
Dannyx321's Avatar
Going to be changing the bottom end if doing lsv? cause i dont think the compression is good enough to run "stage 2 cams"
Anyways what kind of stage 2 cams?
Old 09-03-2012, 09:01 AM
jdmscene87's Avatar
if i went the lsv route ofcourse id be using a ls block such as a b18b/b1 and to bump the compression use p73 itr pistons.
blox b cams
Old 09-03-2012, 09:52 AM
phaphon's Avatar
i hear bad things about supertech valves. i went with ferrea 6000 series on mines
Old 09-03-2012, 10:44 AM
jdmscene87's Avatar
i would say the difference between hearing and having a ST valve go bad on you is only from experience.. If you dig deep enough you will find dirt on every part. No valve is infallable, unfortunately lol.
Old 09-03-2012, 07:26 PM
racebum's Avatar
myles aka gringotegra had a supertech valve literally break in half. wrecked the engine. the fererra stuff is a one piece forging.
Old 09-03-2012, 08:07 PM
Global Moderator
Jimmy's Avatar
Stock ITR.
Old 09-03-2012, 09:03 PM
jdmscene87's Avatar
That Racebum, i will keep in mind and hope i dont blow my itr to pieces..
i may just change the valves while the motor is apart and play it safe
92integraVTECgsr
11
05-29-2008 04:28 AM
842177
10
04-08-2008 07:54 PM
hondaguyexsi
03-29-2005 02:38 PM
BikeSpike
01-01-2004 12:50 PM
JDM DC2 R
01-26-2003 10:29 PM
Quick Reply: b18C itr or ls vtec b18b w itr head
