B18C Head Conversion
Old Jun 2, 2004 | 12:07 PM
NocDyno95Integra's Avatar
Default B18C Head Conversion
Im driving a 95 Integra Special Edition...1.8 L Non V-TEC...all i have on the engine right now is an AEM Cold Air Intake...and soon ill be getting full exhaust. so im thinking of doing a B18C Head swap and staying with the Non VTEC block, and stock transmission cuz it seems to be the quickest way to make my car significantly faster without getting a turbo setup (cuz i dont have the money for a turbo)...is this a common conversion? and is it a good idea? what are some better ideas?
Modified by NocDyno95Integra at 10:21 PM 6/2/2004
Modified by NocDyno95Integra at 10:37 PM 6/2/2004
Old Jun 2, 2004 | 12:09 PM
LSTEG96's Avatar
Default Re: B18C Head Conversion (NocDyno95Integra)
QUICK change ur post!! its vtec. search lsvtec. ull find everything u need to know, then realize u know not a thing, and sell ur car. u can make an ls fast...ur just not smart enough.
Old Jun 2, 2004 | 02:21 PM
VsR785's Avatar
the money u spend doing the ls/vtec u can buy a turbo, and the ls motor is the best for turbo..go turbo **** ls/vtec
Old Jun 2, 2004 | 02:49 PM
zizux's Avatar
I am in a simular situation, but how is the "ls motor the best for turbo" if the head flows like ***?
Old Jun 2, 2004 | 03:06 PM
LSTEG96's Avatar
Default Re: B18C Head Conversion (VsR785)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VsR785 &raquo;</TD></TR><TR><TD CLASS="quote">the money u spend doing the ls/vtec u can buy a turbo, and the ls motor is the best for turbo..go turbo **** ls/vtec</TD></TR></TABLE>
ur dumb.
Old Jun 2, 2004 | 03:20 PM
Kendall's Avatar
It's a very common conversion called LS/VTEC. Please properly research this topic as virtually every question you can possible ask has already been answered numerous times.
Old Jun 2, 2004 | 06:25 PM
I found a used V-TEC Head with 80K for $450 Bucks...ive never seen a turbo kit for less than 1,000...how would it be the same money? Granted, if i was to rebuild the head once i got it, itd be significantly more money...i would still think a turbo would be more expensive.
Old Jun 2, 2004 | 06:59 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NocDyno95Integra &raquo;</TD></TR><TR><TD CLASS="quote">I found a used V-TEC Head with 80K for $450 Bucks...ive never seen a turbo kit for less than 1,000...how would it be the same money? Granted, if i was to rebuild the head once i got it, itd be significantly more money...i would still think a turbo would be more expensive.</TD></TR></TABLE>
The cost will be less than a proper turbo setup, but still more than just the price of a VTEC head. Again, research the conversion, and you'll have a better understanding of just what it involves.
Old Jun 2, 2004 | 09:51 PM
VsR785's Avatar
Default Re: B18C Head Conversion (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">
ur dumb. </TD></TR></TABLE>
**** u loser, its just my opinion, sorry i didnt add that....stupid ****
Old Jun 3, 2004 | 04:53 AM
dcb16's Avatar
Default Re: B18C Head Conversion (vrooom)
search...
Old Jun 3, 2004 | 05:18 AM
hi mom's Avatar
Default Re: B18C Head Conversion (dcb16)
I wouldnt worry about getting a GSR or ITR head.. there not much different from the B16A heads..
I would pick up B16 head, keep the extra money and buy Throttle body, or Intake Manifold.. aftermarket
Neways, yeah, I think I paid about $2000 US for my setup, 195 hp, 158whp..its definently a lot less then a turbo setup would be, Ive researched it for months..
In the end your going to probably going to look at building it, the most Ive seen out of any LS/VTEC is about 210WHP..N/A
Good luck with your setup, if you have any questions just pm me..
Old Jun 3, 2004 | 07:56 AM
Goinfasterthanu's Avatar
ls head flows fine if its got a p&p job on it....
Old Jun 3, 2004 | 10:54 AM
Another question about the conversion...
With the Vtec head, what would i have to do software/computer wise?
Old Jun 3, 2004 | 11:01 AM
r0c5t4r's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">It's a very common conversion called LS/VTEC. Please properly research this topic as virtually every question you can possible ask has already been answered numerous times.</TD></TR></TABLE>
Right on Kendall!
Old Jun 3, 2004 | 05:53 PM
luministic7's Avatar
Default Re: B18C Head Conversion (Kid RS-V)
i'm also new at this honda-tech thingy. I've heard too much rumors about ls/vtec messin up the motor after 20k or so, is this true? They said something like the ls block couldn't take it so oil starts leaking all over.
Old Jun 4, 2004 | 10:20 AM
hi mom's Avatar
Default Re: B18C Head Conversion (luministic7)
^ maybe if they shift at 10k for 20k on stock bottom/top
Ive had mine for about 5000 miles now, and nothing yet..
Old Jun 4, 2004 | 03:03 PM
zizux's Avatar
how many miles did you have on your car before you went ls/vtec?
Old Jun 4, 2004 | 06:30 PM
jamessh1's Avatar
Default Re: (zizux)
okay, the cost for everything in an ls/vtec will be very close to the price of a turbo set-up:
complete vtec head (distributor, IM,TB)=$600 USD
OBD-1 Vtec ecu $175
ARP head and rod bolts $175
ACL rod bearings $50
GSR water pump, oil pump, timing belt $175
you'll probably want high compression pistons (eg, pr3, p30) $280 with rings
gasket set $150
what am i forgetting here......I think that's most of it. good cams and valve springs (eg. ITR) would be another $500 USD used
The install, if you aren't doing it your self add $400 or so USD.
You can add it up, this set-up should be good for around 180 whp (with cams), maybe less, maybe more, depends on tuning.
Modified by jamessh1 at 11:47 AM 6/5/2004
Old Jun 5, 2004 | 08:07 AM
hi mom's Avatar
Default Re: (zizux)
165,000 km's
austinwasthere
Jan 9, 2012 04:39 AM
jim morrison
Dec 25, 2005 07:17 PM
Russo757
Jul 26, 2004 07:31 AM
g's integ
Jun 26, 2002 12:19 PM
integra81
Oct 23, 2001 03:58 AM
