b18c block identification
Old Dec 6, 2003 | 12:38 PM
insomniac791's Avatar
Default b18c block identification
I have a friend that just bought a 00 civic Si with a b18c swap. The place that he bought it from told him it was a Integra Type R motor but on the block stamp all it says it b18c and under that the engine code is 2004549. Is that a GSR motor or a Type R
thanks
Matt
Old Dec 6, 2003 | 12:47 PM
vain's Avatar
Default Re: b18c block identification (insomniac791)
b18c = jdm type-r
b18c1 = usdm gsr
b18c5 = usdm type-r
Old Dec 6, 2003 | 12:57 PM
95 integra's Avatar
Default Re: b18c block identification (vain)
Look at the intake manifold...probably the easiest way to tell. Yes they couldve put a skunk2 on there, but I doubt it.
Old Dec 6, 2003 | 01:24 PM
Damon B.'s Avatar
Default Re: b18c block identification (95 integra)
What is stamped on the head above the header?
Old Dec 6, 2003 | 02:04 PM
AWDxBOOST's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vain &raquo;</TD></TR><TR><TD CLASS="quote">b18c = jdm type-r
b18c1 = usdm gsr
b18c5 = usdm type-r</TD></TR></TABLE>
b18c= jdm itr and jdm siR-g(gsr)
cant you just look at the redline? lol its obvious...just run the motor and see how it pulls
Old Dec 6, 2003 | 02:14 PM
scrap1ngsr's Avatar
Default Re: b18c block identification (ls_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls_teg &raquo;</TD></TR><TR><TD CLASS="quote">
search there was just a thread about this recently
Old Dec 7, 2003 | 03:21 AM
GSRacer93's Avatar
i remember hearing something about the first number in the serial code can denote whether or not the jdm b18c motor is type r or not. if i recall correctly... the 2 does denote it is a type r... but i might need some verification on this.
Old Dec 7, 2003 | 07:33 AM
P1mpSlap's Avatar
bounce it off the revlimiter and see :roll eyes:
Old Dec 7, 2003 | 08:39 AM
scrap1ngsr's Avatar
Default Re: b18c block identification (GSRacer93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRacer93 &raquo;</TD></TR><TR><TD CLASS="quote">i remember hearing something about the first number in the serial code can denote whether or not the jdm b18c motor is type r or not. if i recall correctly... the 2 does denote it is a type r... but i might need some verification on this.</TD></TR></TABLE>
dittto I have heard this too , put it on the dyno and see what kind numbers it pulls
Old Dec 7, 2003 | 11:11 AM
well it does not pull like I thought it would. We went for a ride in it then came back and I took him for a ride in my b16 CRX and and he could not beleive that my crx pulled harder than his Civic? I think the revlimiter is at 8600. It has a Type R intake manifold. So I am stumped?
later
Matt
Old Dec 7, 2003 | 12:10 PM
oMek's Avatar
Default Re: (insomniac791)
look at the intake manafold
the r will come up from the bottom, the gsr will bend twards the bottom.
does it have a red valve cover?
whats it redline at?
if its a jdm R it should have 4-1 header with a 2.5 collector
also ive heard that on the head rightr bhind the dizzy the Rs have green paint there for some reason (dont quote me on this)
Old Dec 7, 2003 | 01:35 PM
it has the R intake manifold
The valvecover is wrinkle red not spray paint
I don't know what redline is but his fuel cutoff is 8600 I think
I really did not look that closely at the exhaust manifold
I did not see any green paint anywhere
Shouldn't a b18c5 in a 00 Civic Si pull harder than my b16 91 CRX Si?
later
Matt
Old Dec 7, 2003 | 01:42 PM
E36 Guy's Avatar
just look at the head, if its stamped pr3 then is a R. if its stamped p72, its a gsr, end of story
Old Dec 7, 2003 | 01:45 PM
gsrintegra1976's Avatar
Yes it should pull harder . Even if it's the sirg motor .
Old Dec 7, 2003 | 04:31 PM
stevieteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by insomniac791 &raquo;</TD></TR><TR><TD CLASS="quote">
In theory yes, are you running a stock b16? Being a jdm motor no ones really knows the past life of the motor, or the condition. Has a compression or leakdown test been done yet
Old Dec 7, 2003 | 11:46 PM
GSRacer93's Avatar
does it have the correct ecu? (don't know if that would make a difference though)
thunderboy
May 3, 2010 07:42 PM
tHeeeazy E
Mar 28, 2006 10:52 AM
-_My92DA_-
Mar 27, 2006 04:32 PM
gtgoku
22
Sep 24, 2004 07:30 AM
Jflex
17
Apr 14, 2004 11:45 AM
