B18c
Old Feb 4, 2021 | 01:20 PM
Austin Weir's Avatar
Default B18c
Hello I have a b18c gsr and I'm doing the timing on it im using aem trutime cam gears and when I try to line the top marks up the parallel lines dont line up there about 1 tooth off. Is there something I did wrong? Thanks
Need help the parallel lines dont line up there aem trutime cam gears for a b18c gsr what am i doing wrong?
Old Feb 4, 2021 | 04:36 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: B18c
Make sure they are at the 0 mark on each cam gear. Both look off! If so loosen each bolt and adjust it to 0 and tighten the bolts back down. If you dont plan to use the cam gears I would just save the head ache and use stock gears, those and other cam gears can become loose and slip your timing and F your engine up. Unless they have the locking design like the Bisi Moto cam gears.
You may have to rotate the left gear a little to line them up when putting the belt on.
Use this tool its cheap and holds the cams so you can put the belt on easier with out the gears moving on you,
B-Series Engine Cam Gear Lock Timing Belt Tool For Honda Acura B16 B18 Civic USA | eBay
Old Feb 4, 2021 | 04:42 PM
Default Re: B18c
Both cams the zero mark is at the top as indicated by the circle with the line thru do they need to be at the top or horizontal? If the zero mark is supposed to be at the top I don't know why the side line markers aren't lining up?
Old Feb 4, 2021 | 06:35 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: B18c
Post up close pics of the cam gear settings.
Try picking up a Haynes manual on how to set the timing belt it comes in handy on days you have a head ache doing these jobs.
Old Feb 5, 2021 | 07:32 AM
Default Re: B18c
Close up pictures of both cam gears as straight as I can
Old Feb 5, 2021 | 11:09 AM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: B18c
Just use that tool i posted to lock them in straight. They wont line up perfect without moving one of the cams try the left cam. Make sure the crank is at TDC and lined up with the oil pump mark then install the belt.
Old Feb 5, 2021 | 11:13 AM
Default Re: B18c
Ya I turned the cams so the horizontal lines are matching and the belts on now. The intake is at 5 and the exhaust is at 2 now instead of both at 0 and the crank sprocket is lined up with the oil pump mark
Jmx305
Feb 10, 2014 08:57 AM
JBLAZE622
Jun 3, 2010 03:32 AM
00-501itrspec
Dec 2, 2007 11:33 AM
killacam661
Aug 31, 2007 11:30 AM
turbotime
May 14, 2006 04:06 PM
