B18b1 normal compression??
Old 03-10-2012, 11:21 AM
DelSol-B18's Avatar
Default B18b1 normal compression??
Hey ht this is kinda dumb lol but I'm about to do a compression test on my b18b1 how many psi am I looking for 180+? Also, it smokes a little on start up and when I slightly take off, but anything after that it's good. Valve seals? And yeah how many psi am I looking for when doing compression test? Thanks
Old 03-10-2012, 11:51 AM
The Grumpiest
grumblemarc's Avatar
Default Re: B18b1 normal compression??
Just do the test. Report back what you get.
Old 03-10-2012, 01:12 PM
DelSol-B18's Avatar
150 135 135 150
Old 03-10-2012, 01:37 PM
The Grumpiest
Found this on the net for your reference.
(nominal= good)
(minimum= anything below this and you need to start worrying)
(max var: maximum variation between cylinders. ie Cyl 1=190, cyl 2=150, you have a problem)
Gen 1
86-89 d16a1
nominal: 192 psi
minimum: 134 psi
max var: 28 psi
Gen 2
90-91 b18a
nominal 185 psi
minimum: 135 psi
max var: 28 psi
92-93 b18a1
nominal: 199 psi
minimum: 135 psi
max var: 28 psi
92-93 b17a
nominal: 199 psi
minimum: 135 psi
max var: 28 psi
gen 3
94-01 b18b1
nominal: 199 psi
minimum: 135 psi
max var: 28 psi
94-01 b18c1
nominal: 270 psi
minimum: 135 psi
max var: 28 psi
97-01 b18c5
nominal: 270 psi
minimum: 135 psi
max var: 28 psi
gen 4
02+ k20a3
nominal: (?)
minimum: 135 psi
max var: 28 psi
02+ k20a2
nominal: (?)
minimum: 135 psi
max var: 28 psi
Old 03-10-2012, 03:14 PM
Daisy... Daisy...
Dogginator's Avatar
The absolute number is highly dependent on the compression tester, engine temperature, etc. The consistency of the readings is not.
OP, adjust your valves and retest.
Old 03-10-2012, 04:57 PM
DelSol-B18's Avatar
Engine was at operation temp. And do a valve lash adjustment? And see if it smokes still and see if compression is better?
Old 03-10-2012, 06:11 PM
el crapitan's Avatar
and you're testing at WOT,yes?
what color is the smoke?
the lower compression in 2 adjacent cylinders is synonymous with a breached headgasket due to a warped/cracked head.
try running a wet compression test. see how the numbers differ from the dry
Old 03-10-2012, 06:39 PM
DelSol-B18's Avatar
Blue smoke. And are you saying I might have a warped head?
Old 03-10-2012, 06:41 PM
DelSol-B18's Avatar
And no just crank not pedal wide open
Old 03-10-2012, 08:27 PM
test with pedal at wot. this keeps the pcm from fueling and washing the cylinders
brent_G
10-12-2003 12:15 AM
zojirushi
05-22-2003 08:03 AM
fastlude69
05-13-2003 07:30 AM
d15nonvtec
02-04-2003 07:31 PM
Quick Reply: B18b1 normal compression??
