b18b1 bouncing idle
Old May 13, 2011 | 04:14 PM
TheAngryGinger's Avatar
Default b18b1 bouncing idle
i just bought a 96 integra ls. the last owner blow the stock ls and bought a cheap b18b1. at an idle it either stays high at around 3000rpm or bounces around 2000rpm. im not good with diagnosing engine problems so where should i start?
thanks.
Old May 13, 2011 | 05:17 PM
EJ1_CRIS_909's Avatar
Default Re: b18b1 bouncing idle
A quck google search could have got u an answer. Clean the iacv, check the fitv, and look for vaccum leaks.
Edit::
Also make sure your cooling system is properly bled
Old May 14, 2011 | 09:49 AM
i cleaned the iacv and fitv and it no longer bounces but the idle a little high. around 1300rpm. what else should i do to bring down the idle.
Old May 15, 2011 | 12:08 AM
efkilla's Avatar
this is the idle screw in is lower and out is higher also make sure the throttle cable is adjusted right
CaliforniaDad
Mar 15, 2012 04:59 PM
zoidburg
Dec 21, 2010 06:36 PM
Cuong-nutz
Nov 25, 2004 10:34 AM
350z-tech
Nov 10, 2001 10:46 PM
