b18b pcv question?
Old Jun 25, 2009 | 08:31 AM
d16trexin's Avatar
Default b18b pcv question?
hey i got a freind that has a 95 integra with a b18b and when he bought it it was burning oil real bad so we put new rings and new valve seals and replaced bascally every gasket. after we did all that and got it running again it was still burning oil so went to replace the pcv valve and noticed that the the little black plastic housing that the pcv valve goes into did not have a hose running off of it into the black box on the back of the block. we also noticed that there is another hole on the black box. i was pretty sure that this was his problem why he was burning oil and his car was smoking badly still. would this cause the car to smoke bad? also i need to know what is suppose to be running to the other hole in the black box, i know 1 hose is suppose to run from the black box to the pcv alve but what is the other hole for, are we suppose to run a hose from that to somewhere else also. any help would be appreciated i think were finally about to figure this thing out
Old Jun 25, 2009 | 08:42 AM
ek-g6's Avatar
Default Re: b18b pcv question?
one goes to the block I believe and the to pcv valve. I would replace that pcv, it's only 5 bucks and yeah when it gets clogged it'll throw oil into intake manifold.
My_EFsedan
Dec 20, 2009 09:00 AM
d16trexin
Jun 25, 2009 09:34 AM
scottishdave
Jan 21, 2006 08:15 AM
euclid
Oct 7, 2004 07:16 PM
PROFILES2000
Nov 4, 2001 06:24 PM
