b18b engine.
Old Mar 16, 2005 | 06:33 PM
jeebers02's Avatar
Default b18b engine.
hey everyone,
Here is a little background.. We have a b18b motor ( 94+ Integra non vtec motor) in a 92-95 hatch.. The problem we are having is when the motor gets up the temp and then the motor shuts off... We checked the fuel filter seemed like the gas was getting to the fuel rail and when we turn on the accessory key fuel comes out of the line. so we ruled out the fuel pump.. We are at a loss right now on what else it could be.. Any suggestions would be appreciated. Thanks in advance!
Old Mar 16, 2005 | 06:53 PM
PLAGUED_DB7's Avatar
Default Re: b18b engine. (jeebers02)
check dist, Cap, rotor, Make sure you are not throwning codes...check for spark, you can pull a plug out make sure its a lil dark outside, turn the the engine, and put the side of the plug on a ground point, check air filter, cables, all sorts of ****...get a helms manual on a integra that has the engine good luck
FuLlRaCe XLR8R
Mar 5, 2007 04:42 PM
blk_eg4
Aug 3, 2006 08:27 PM
logikalfury
May 27, 2006 07:54 AM
eric416
Oct 10, 2005 09:29 AM
volcom40street
Sep 1, 2005 08:55 PM
