b17 on b18
Old Feb 14, 2012 | 09:07 AM
lev253's Avatar
Default b17 on b18
so i wanna know if i can put b17 head on b18c1 block. i recently bild my block but ran out of money to do my P72 head. but i found b17 head already done
how i wanted. first i was looking for bild b16 head but they r hard to find and for me its cheaper to get one that all done.
so what will you suggest which is better b17 b16 or gsr heads
Old Feb 14, 2012 | 09:25 AM
DirtyDA9's Avatar
Default Re: b17 on b18
It will work, but you can't use your GSR intake manifold on it. I would stick with your GSR head though and build that.
Old Feb 14, 2012 | 09:57 AM
doood's Avatar
been there done that
fyi, b17 and b16 heads are the same
Old Feb 14, 2012 | 10:42 PM
JdmTypeRdc2's Avatar
GSR head is better. Flows about the same, and has smaller combustion chambers.
I Would stick with that if you already have it.
Old Feb 16, 2012 | 11:47 AM
lev253's Avatar
ok i c. it will cost me twice as much to build mine then to buy one that's already done.
thanx ill look around more for like a month. see what i can find
Old Feb 16, 2012 | 12:34 PM
B20ztek's Avatar
I have a P&P b16 head complete, gsr cams blox fpr with dizzy and vtec solenoid, if your interested.
Old Feb 16, 2012 | 12:48 PM
DirtyDA9's Avatar
Then buy it. Sell your GSR head for $400 assembled.
Old Feb 16, 2012 | 01:28 PM
Tylermiller888's Avatar
I would rather take the extra time to build my own, I've seen alot of people get screwed buying "already built" heads.
Besides, then you can say you did it, and claim bragging rights.
Old Feb 16, 2012 | 02:31 PM
DirtyDA9's Avatar
^^ lol @ bragging rights. cause everyone wants to be E-famous.
Old Feb 16, 2012 | 03:03 PM
sebTeggy's Avatar
^ doesn't have to be online bragging
Build it yourself man. Sorry to say this, but if the guy is selling a perfectly built head for ag ood price, you have to ask yourself why?
Post some pricing details on the b17 head, and also what needs to be done on your head.
Old Feb 16, 2012 | 03:14 PM
Deetz's Avatar
Crazy Honda Guy
As mentioned earlier in this thread, the B17 head is just a PR3, same as any B16 head and same cast as te Type R
Both the PR3 and P72 heads are very good, one is no better than the other
Old Feb 16, 2012 | 04:16 PM
DirtyDA9's Avatar
^^ I think the P72 is better. Just my opinion, but I'm sure a lot of other people here will agree.
Old Feb 17, 2012 | 05:41 AM
Deetz's Avatar
Crazy Honda Guy
Meh, the p72 makes a couple hp to the wheels more in the low rpm, the pr3 a couple more in the higher rpm, big woop.....you wouldn't even notice it. I have both and tried them i many applications.
I don't know why anyone says one is better
Here's a dyno graph, stock for stock
Old Feb 17, 2012 | 08:15 AM
DirtyDA9's Avatar
Two words, quench pads
Old Feb 17, 2012 | 11:11 AM
lev253's Avatar
ok i like this thanx
cuz i got 8500rpm at 7400rpm it pushes 165hp to the wheel and at 8400rpm it drops to 150hp
most ppl say it cuz i build my block but not my head so the air doesnt flow good after 7400rpm. thats why it loses power.
Old Feb 17, 2012 | 07:20 PM
Does it really have to be "E-famous"
I mean I don't know how it is in your scene, but in MS, the scene is little, so the people who do their own work and build their own motors, get more respect, and if I build a motor and its fast, I'm gonna brag.
What all I said boils down to is:
Fast and Furious rant about respect.
Old Feb 17, 2012 | 08:32 PM
DirtyDA9's Avatar
It's not how you stand by your car, it's how you drive your car
Old Feb 17, 2012 | 10:44 PM
Bond's Avatar
They may have more material at the quench pad area but both heads have "quench pads"
If you look at both heads side by side you will see how very little more aluminum the GSR has over a PR3 casting. It's such a small amount I wouldn't even worry about it. I had both on hand and still went with my PR3. It was in better condition and I already had a port match intake manifold. If not I would have went with the GSR.
In the end the op should build whatever is going to fit his budget and is in better condition.
The GSR vs. ITR head topic is a beaten horse we all love to whip just once more...
It's all in good discussion lol
Old Feb 18, 2012 | 11:32 AM
DirtyDA9's Avatar
^^ You make a good point, but that little amount does raise compression, and helps with detonation a tad more.
Old Feb 18, 2012 | 04:10 PM
Deetz's Avatar
Crazy Honda Guy
i hope you realize the difference in raising compression is only 0.1
So if you had a b16 with 10.2:1 compression, using a gsr head would bring it to only 10.3:1
In my opinion, the "only" advantage to a gsr is the quench area of the bowls are just slightly better for detonation resistance under boost applications
hondachris1994
Sep 6, 2006 06:23 PM
maxheat
24
Feb 26, 2005 12:36 PM
.ShawnD.
21
Jul 17, 2003 08:15 PM
1.8T_EG
Oct 21, 2002 08:53 AM
MrSmith
Mar 23, 2002 01:30 PM
