b16 problem
i have a 1990 acura integra with a b16 block gsr head.well for one, the motor revs up to about 3000 rpm, an have oil leaking,seems like its in the front and the side beside the cams.i already know that i have to change the valve cover gasket because one of the o rings slip and now there is oil in where the spark plugs are.o and if any one know how i could get that out with out taking off the head would be a great help.i am new at the forum thing so could some1 help me out
sounds like u need a new valve cover gasket set from honda. you dont need to pull the head. remove the valve cover and replace the valve cover gasket and the circular spark plug gaskets. cheap fix.
but wat about the oil that is already where the spark plugs are when i take the spark plugs are there is oil in there how go i take the oil out.AND down were the cams are there is oil leaking from some where but cannot pinpoint it out and also oil leaking from somewhere over where the vtec silinoid is.
buy some hondabond or high temp sealant and a valve cover gasket set from honda. part 16 http://www.hondapartscheap.com/south...t=0&quantity=0
take off your valve cover. remove the old gaskets including the rings around the spark plug holes. remove the spark plugs and clean them off. affix your new valve cover gasket and apply some hondabond around the cam depressions on each side and around the edges, thats it. put your NEW ring gaskets in for the plugs and reinstall your plugs.
And if its reving to only 3000 your in limp mode you need to check what trouble codes you a getting.
thanxs alot will do that.acually wen i checked it reved to 2000 rpm..... wen i looked at the ecu it flashed 7 times back to back and then 2 short long blinks then 1 quick blink after.then it jut repeat the again.wat do u think it is i dont know how to read the blinks.
Sounds like a code 7 and a code 21...tough to tell unless I am there though...Also, there is no "limp mode" on an OBD0 car. As for the oil leak...the cams go across the top of the head...do you mean it is leaking near the cam gears? To post pics you need a photo page that lets you download your pics and then gives you the correct format in which to post them on sites like this. An example is photobucket. Good luck!
I have never seen someone type so horrible in my life. If you are having oil leaks check and replace your gaskets on the head like Hondretti said. The oil that got into the cylinders will be fine, gas is made of oil it will just burn off with the gas. Unless your cylinders are full of oil, I wouldn't worry about it.
ok dude, pull you plug wires, stuff shop towels down on top of the plug and soak up as much of the oil as you can before you pull that plug out, don't just all the oil dump down in the motor if you can help it.
keychild486
Aug 15, 2008 04:12 PM
SuicideSlide
Feb 14, 2007 04:53 AM
