b16 in da
Old Aug 28, 2005 | 09:15 AM
turbob16ef's Avatar
From: if you build it they will come, the bottom carolina, duh
Default b16 in da
i was thinking of swapping the ls i have in my da right now for a jdm 1st gen b16. The ls in it right now is already turboed and was thinking if i should go head and do it if its worth it. running 10lbs. and do you guys think it would make it faster. going to put the b16 tranny with the swap if i do it.
Old Aug 28, 2005 | 09:20 AM
Cliffjumper2's Avatar
Default Re: b16 in da (turbob16EF)
this has been discussed many times on here if you care to do a search for b16 in the integra forum archives, you will find a great deal of info.
imo, due to the weight of the integra, you would be better off avoiding the b16 motor, and just swap in the b16 tranny onto the LS long block, then turbo the LS motor if you want.
Old Aug 28, 2005 | 09:28 AM
skunkintegra's Avatar
Default Re: b16 in da (Cliffjumper2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cliffjumper2 &raquo;</TD></TR><TR><TD CLASS="quote">you would be better off avoiding the b16 motor, and just swap in the b16 tranny onto the LS long block, then turbo the LS motor if you want.
werd
the stock B18 will have more torque than the stock B16 could dream of.
simply swap the b16 tranny onto your b18 and call it a day
my .02
Old Aug 28, 2005 | 09:39 AM
turbob16ef's Avatar
thanks will search
Old Aug 28, 2005 | 01:02 PM
importdays's Avatar
u want to swap a turbod motor for a b16??????????????????
Old Aug 28, 2005 | 01:08 PM
Lauj87's Avatar
i'd say keep the Ls motor..and if your planning on swapping trannys its gonna be quicker but not faster.....short gears...alotta torque from the turboed LS motor...might give you too much wheel spin of the launch..soo depends on you....if you have slicks then your okay.
Old Aug 28, 2005 | 02:49 PM
kdawgy2k1's Avatar
yeah... to make a long story short i hade a 75 shot or nitrous on my ls integra for a year and a half and it basically wore it out ( knew it was gonna happen over time ) but im currently doing a b16 swap starting tomorrow and i hope all goes well.... im keepins it OBD-0 and keepin the LS trans ( i know its gonna fall out of vtec when shifting ) but i prefer the longer taller gearing cuz its still the daily driver and i will be traveling with it... why dont you slap the turbo kit on the b16 with ahead gasket??? it will smoke the ls??
Kellen C
Swift Racing Tech
301-982-4600
Old Aug 28, 2005 | 03:38 PM
turbob16ef's Avatar
thats what my plan was to do swap the engine and leave the turbo kit in there
bbrian
39
Aug 4, 2012 05:48 AM
Alexpbnj
Mar 24, 2011 06:52 AM
ahron
33
Dec 31, 2007 11:14 AM
Austinbionic316
May 30, 2004 07:18 PM
theSYNDICATE
Feb 9, 2004 05:54 AM
