Axle problem
im juzt wonderin if anybody can help me answearin this question...i got a 94 GSR but the problem is my Driver side Axle is gettin really bad and makin click noise...i kno i do have to change it now but the main question is could i get a LS axle and swap it into mind if not dawm!!!!! but if i can swap it what is the difference of it if there is?????
Yes, you can use it. All B-series axles are the same. If you have ABS, get ABS axles. It's also the same, but with the metal "sensor" ring around the outer boot.
eggsi619
Oct 13, 2022 02:57 PM
eggsi619
Oct 26, 2009 09:37 PM
