axle
Old Aug 22, 2006 | 12:11 PM
StolenTeg's Avatar
Default axle
when puttting the axles back on, do i need to tap it in lightly or should i just slide in? It seem the snap on ring in stopping it from going in and i wanted to make sure it fine hitting it with a rubber mallet to help it slide in.
Old Aug 22, 2006 | 12:22 PM
PrinceAli132's Avatar
Default Re: axle (StolenTeg)
I was having the same problem last week. I did some research and everyone said that is should slide right in. The intermediate shaft was pretty straight forward after a few tries it went it all the way. But the passanger side was a completly different story. No matter how many times i tried it wouldn't budge after going in a little bit. I ended saying screw it and took a rubber mallet and gave it a few slight nudges and i mean i was real careful about not missing and not hitting to hard and it kind went in a bit more and i was able to slide it in the rest of the way.
Edit - its been about 200 miles and everything seems ok still.
Ali
Old Aug 22, 2006 | 07:08 PM
BlueIntegraBoy's Avatar
You have to tap lightly at the other end of the axle for the snap ring to seat correctly.
spotrep
Transmission & Drivetrain
Jan 24, 2013 06:54 PM
RanCRX
Dec 28, 2009 03:03 PM
sirt_eg
Jun 11, 2007 03:02 AM
pprowler6
Jan 22, 2007 10:14 AM
Mavrick
Nov 11, 2005 11:14 AM
