Autometer Temp Gauge, Quick ???
Old May 7, 2005 | 08:39 AM
Racermech's Avatar
Default Autometer Temp Gauge, Quick ???
I am looking at getting an Autometer water temp gauge. The electric gauge has a range from 100-250F. Is this enought range? Or the mechanical has a range of 140-280, or 60-210. But i want to stay away from the mechanical.
What is the normal temp for our cars?
Thanks
Old May 7, 2005 | 09:31 AM
EnjoyTheRideDC2's Avatar
Default Re: Autometer Temp Gauge, Quick ??? (Racermech)
the electric is fine. I run one myself. 172, thermo opens, 200 deg. fan turns on, anything above 210 is warm-hot....
Old May 7, 2005 | 10:42 AM
mr.beeks's Avatar
most car operating temp runs between
170-200 so you should be good on the electric
not only that it depends where you are placing the
sensor...
Old May 7, 2005 | 06:31 PM
Default Re: Autometer Temp Gauge, Quick ??? (mr.beeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">most car operating temp runs between
sensor...</TD></TR></TABLE>
Very true. If you use the one supplied with the Autometer Gauge, you should be fine.
Old May 7, 2005 | 06:57 PM
Racermech's Avatar
Default Re: Autometer Temp Gauge, Quick ??? (EnjoyTheRideDC2)
That was my next question, what is the best place to hook it up?? I thought i could splice it into the factory temp sender (on the thermostat housing), is this correct, or is there a better place to hook it up?
Old May 7, 2005 | 08:11 PM
cjohnson_2's Avatar
hook it up to the aluminum hose connector on the front side of your block where the "exit" of the coolant is for your head. That way if you blow a head gasket youll see a huge temp spike on your temp guage and know it before your car actually overheats. FYI the stock temp guage is hooked up to the "IN" of your head.
Old May 7, 2005 | 09:14 PM
IntegraChick's Avatar
EnjoyTheRideDC2, I do not have permission to participate in the DB Squad. I'm still on trial. Would you be able to ask Mattminer where he got his cool looking Honda steering wheel on his 4 door Teg? Thanks.
Old May 8, 2005 | 06:08 AM
Racermech's Avatar
Default Re: (IntegraChic)
Hey Noob, thanks for the thread hijack, why dont you click the link in his Sig for info on the DB squad...... and then <A HREF="http://albinoblacksheep.com/flash/posting.php
" TARGET="_blank">click here</A>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjohnson_2 &raquo;</TD></TR><TR><TD CLASS="quote">hook it up to the aluminum hose connector on the front side of your block where the "exit" of the coolant is for your head. That way if you blow a head gasket youll see a huge temp spike on your temp guage and know it before your car actually overheats. FYI the stock temp guage is hooked up to the "IN" of your head.</TD></TR></TABLE>
Now this is the hook up for the mechanical or electric gauge??
Disco
May 23, 2013 11:17 AM
clsmooth
Feb 4, 2004 10:26 PM
