Automatic to manual swap, Need different front springs?
Old Apr 8, 2007 | 11:16 AM
doubleA's Avatar
Default Automatic to manual swap, Need different front springs?
I recently bought a 98 integra which was originally a automatic. The previous owner swapped in a manual transmission and changed it to obd1. Everything works great but last night I pulled up nose to nose with my friends 97 integra and mine sat a good 2-2 1/2 in higher in front. Both our tegs are ls model with stock suspension. The only difference is my teg has the ac and ps stripped out.
Im wondering if the automatic is heavyer than the manual trans and so honda gave the auto's a heavyer front suspension? Thanks for any help..
Old Apr 8, 2007 | 12:44 PM
BlueIntegraBoy's Avatar
Default Re: Automatic to manual swap, Need different front springs? (doubleA)
Do you have larger rims? The springs are the same between auto and manual.
Old Apr 9, 2007 | 06:16 AM
doubleA's Avatar
Default Re: Automatic to manual swap, Need different front springs? (BlueIntegraBoy)
yes, I do have a set of fat fives on and my friend has his stock steelies. It the wheel gap im worried about, the front has so much more than the back.
Old Apr 9, 2007 | 04:29 PM
Tonyl507's Avatar
I came across the same thing. Everyone says, including honda, that the springs for manual and auto are the same, but when I did my auto-manual swap, my car now sites ~1 inch higher in the front. I'm 100% sure b/c I measured it in the same spot before and after.
I guess its b/c the auto tranny is alot heavier.. debatable that it would cause a 1" diff tho - But my car is proof... i was surprised.
(NO change in rims/ a/c / power stering, etc. either..)
Nikademo
Acura TL, RL & ZDX
Jan 14, 2017 11:03 PM
tripledubz
Aug 12, 2015 05:55 PM
limit
Jan 26, 2009 12:27 PM
eg_ruoner364
Jun 18, 2008 12:04 PM
ericjackson
Jun 21, 2005 01:52 PM
