automatic to manual conversion
Old Feb 6, 2007 | 06:13 PM
Spazbaboon's Avatar
Default automatic to manual conversion
Has anyone done an automatic to manual conversion? I bought my car in August and put an additional 1500 into it since and I really dont want to sell it and buy a new car. However im regretting buying an automatic, has anyone done the conversion? If so how long did it take, how much etc
Old Feb 6, 2007 | 06:27 PM
lVlemphizStylez's Avatar
Default Re: automatic to manual conversion (Spazbaboon)
I did it...roughly 1k in parts..Didnt pay for labor
Old Feb 6, 2007 | 07:23 PM
9311dan's Avatar
I did in my DA....
Upgraded Parts I used:
B16 Cable Trans
Clutchmasters Stg 1 clutch
Clutchmasters Stg 1 PP
Clutchmasters Throw-out bearing
Clutchmasters 8 lb flywheel
B&M short throw shifter
Mandatory Parts:
pedal assembly
throttle cable
clutch cable (i dunno if you're cable or hydro)
shift linkage
shift rod
clutch cable brackets (2 on VC and one on trans)
MT intake manifold
MT ECU
MT reverse plug (wire to reverse lights)
MT Cluster (optional, but much cleaner)
MT axles
Shifter Bushings
Check brake pedal pin and codder pins
Trans mounts
MT Starter Mounting Bolts (longer)
Shim PS Motor mount so motor is level (need a screw longer than OEM screw to do this)
Make sure you have ALL your tranny case bolts, i was missing 4 and had to order them
Plate for linkage mounting
ah it's late....that's all I can remember for now.
if you need more info just let me know...
Old Feb 6, 2007 | 10:54 PM
nate_2k5's Avatar
Default Re: (9311dan)
its a real pain in the ***, i had the same problem as you, bought an auto then quickly put more in parts on it than i had bought it for. i ended up getting a manual and swapping the parts onto it
Old Feb 7, 2007 | 01:12 PM
9311dan's Avatar
yeah, but now that it's done I can say that my car is the only car in my area that's got an AT-MT conversion, lsvtec conversion, and OBD0-OBD1 Conversion....lol FTW.
lilchris813
Dec 23, 2013 05:48 PM
cpat
Transmission & Drivetrain
Oct 28, 2012 04:54 PM
MrFunCRX
18
Dec 19, 2009 09:33 AM
heavyhittersclub
Jun 16, 2007 11:16 AM
wronghand
Apr 12, 2002 09:02 PM
