Auto to Manual Swap (This should be a Sticky)
#26
Re: Auto to Manual Swap (Integra_Nguyen)
The harness should be under where the cup holders are.
The clip that plugs into the harness is what is pictured. It was was from the white box that was on the auto shifter. What I did was unclipped the white box from the harness and cut it off. Then I connected the wires and plugged the clip back into the harness.
#29
Re: Auto to Manual Swap (integra_dreamz)
then go out and buy a gsr tranny and the parts and get to work dude...you can get this stuff piece meal instead of all at once....and youll be surprised to see how quickly youll get things done
#31
Re: Auto to Manual Swap (usdm97DC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdm97DC4 »</TD></TR><TR><TD CLASS="quote">this write up is JUST what i needed. But where do i find all these mounts? i have the hasport one already though...where do i get the others?</TD></TR></TABLE>
I got them straight from Acura...the front tranny bracket. I actually got the rear tranny bracket from someone here on H-T. Just do a search for tranny mounts. The only "mount" though is the custom upper tranny mount. The others don't have any rubber mounting to them, just metal brackets. From Acura they're about $30-40 a piece. Try that if you can find it here. It's not bad. I got the clutch lines from Acura as well. Cheaper if you get them from the 01 Teg models.
#32
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra_Nguyen »</TD></TR><TR><TD CLASS="quote">
I got them straight from Acura...the front tranny bracket. I actually got the rear tranny bracket from someone here on H-T. Just do a search for tranny mounts. The only "mount" though is the custom upper tranny mount. The others don't have any rubber mounting to them, just metal brackets. From Acura they're about $30-40 a piece. Try that if you can find it here. It's not bad. I got the clutch lines from Acura as well. Cheaper if you get them from the 01 Teg models.</TD></TR></TABLE>
ohh alright cool. isnt the hydro line like 40 bucks for half then 60 for another half? thanks for this great info!
and were can i find the clutch to flywheel bolts?
#33
I'm planning on dropping a GSR with manual transmission into my Automatic LS. My manual transmission has a mount on it, the one on top with the three bolts. Is that the Manual Front Tranny mount your talking about, or do I still need to buy one from Hasport? I have the rest of the parts to pull this off, I'm just trying to figure out the exact brackets and mounts that I need. Can you explain the difference's between #'s 6-9? and you said Acura has #'s 6-8 to buy? Thanks for help.
#34
official honda whore
Re: Auto to Manual Swap (dannykointegra)
thanks for the photo of the plug, i just did mine and it started up without hooking the black wires together, i went to eat, came out and it wouldnt start, somehow it ended up messing up and i had to wire the black wires together, but then again i have a 5 speed ignition etc
#35
hold up, i just purchase an upper manual mount. This mount wont work? and needs to be modified?
this sucks man....
do you have a web site to where i can purcahse one that doesnt need to be modified.
which mount is it? i cant find it on their site.
they are selling complete kits.
Im looking for one particular mount right?
this sucks man....
#36
Re: Auto to Manual Swap (confucius)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confucius »</TD></TR><TR><TD CLASS="quote">hold up, i just purchase an upper manual mount. This mount wont work? and needs to be modified?
this sucks man....
Im looking for one particular mount right?</TD></TR></TABLE>
did you make sure you got the auto-manual conversion mount? not just the manual mount? my hasport box said "manual transmission conversion mount for the 94-01 integra chassis.....DCAMH-62A"
link..
http://hasport.com/catalog/pro...d=121
this sucks man....
link..
#37
hey thanks for the link man. i honestly could not find it.
now i need a link to get the mounts or brackets for the rest of the tranny.
i clicked on acuraautomotiveparts.org and then clicked on engine mounts. but i cant find the mounts or brakets the topic creator was referring to.
anyone?
thanks in advanced.
anyone?
thanks in advanced.
#38
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confucius »</TD></TR><TR><TD CLASS="quote">hey thanks for the link man. i honestly could not find it.
anyone?
thanks in advanced.</TD></TR></TABLE>
From another thread by AzN_Flava you need, "according to this, you need parts 11 BRACKET, RR. , and 15 BRKT, R. FR. STOPPER "
Seen here.....
http://www.acuraautomotivepart...MOUNT
Make sure on acuraautomotiveparts.org you selected "KA5MT" for your transmission if you didn't considering you'll have a 5 speed manual transmission.
anyone?
Seen here.....
#39
is this one of them? cuz i bought this one thinking it was the upper tranny mount, and later found out that i needed a custom one for the auto to manual.
#40
That looks like an upper tranny mount for the front that goes under the air-intake sort of. The only rear one you need is one that looks like a "T". Ill take a pic of my hasport one on my tranny tonight.
#41
Re: Auto to Manual Swap (masterasia)
Where were you a year ago when i was getting this done. I searched out parts for a year and was finally able to have it done when i found someone willing to do it for 1/3rd the cost of all the major shops. I would have loved to do it myself but i could not risk any major downtime on my car, and at that time there was no How-to on the subject like this one. Great write up and i hope that it helps some people do this swap. And to anyone considering this swap, do it or sell your auto and buy a manual teg. It cost me a bit of money but it was worth every cent.
#44
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confucius »</TD></TR><TR><TD CLASS="quote">the one i bought from hasport does not look a 'T'
so I sill need bracket 11 and 15 from acuraautomotiveparts.org?</TD></TR></TABLE>
Noooo the Hasport one is the front upper mount, the only REAR one you need from Acura and im not sure which one it is exactly...but it looks like a T.
#47
This is a great right up
My only question is: I have a eg coupe AT that I want to swap in an H22, does this mean I also need to purchase this adapter bracket, or does my buying the H22 mounts eliminate this need?
#48
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannykointegra »</TD></TR><TR><TD CLASS="quote">Im guessing "11 BRACKET, RR", which looks like a "T" is different for automatics and manuals, correct?</TD></TR></TABLE>
Im not too sure which one exactly...but I will find out.
#50
usdm97DC4 you seem to know what you're talking about with this subject, could you help me out with my above question? Please...
Thanks
Thanks
