ARP rod bolts for b18.. should I or not?
Thinking bout picking up some arp rod bolts for 40 bnib for b18 locally... seems hella cheap. is there anything i should look out for or ask before i go through with transaction? how much do they usually go for? i saw some for like 200?
Old Fart
Re: ARP rod bolts for b18.. should I or not?
If they are not from an authorized dealer, you can't be sure they are real, and you definatly do not have warranty even if they are real, most of the time you do get what you pay for. 94
LS engines will use the 8mm rod bolts. you can get those for $40 anywhere.
b18c will be the 9mm bolts, which are about $80.
I would just order some new ones. The last thing you wanna do is find out that they arent real and snap when your torquing them down. Thats alot of trouble just to save a little money. Not worth the hours it would take to replace them
Hype-R Stalker
