ARP HEADSTUDS LEAKING?
Old Jun 27, 2009 | 02:48 PM
snowpro127's Avatar
Default ARP HEADSTUDS LEAKING?
I was just wondering if anybody had this problem with Arp Headstuds leaking.My Machine shop just finished my head and i was gonna go with arp for my headstuds and, then he told me he has had problems with them leaking, he told me to go with oem.
Old Jun 27, 2009 | 02:53 PM
stevenDAtegra's Avatar
Default Re: ARP HEADSTUDS LEAKING?
Like causing a leaky headgasket? ARP are much better.
They also do something head studs don't, something like instead of pushing the head down, squeezing them. lol, I read it on there site somewhere about how it makes a difference.
Also, aren't they a lot more re-usable than headbolts?
You also get better torque loading
Old Jun 27, 2009 | 03:01 PM
snowpro127's Avatar
So you never heard of it causing a leaky headgasket I thought he was crazy when he said that but i was just wondering before i put this head on
Old Jun 27, 2009 | 03:10 PM
vtechjunkie's Avatar
Never heard of that. With so many people standing by them, I don't think that happens much. My machinist used to do work on "NASCAR" motors, and still works on circle trackers regularly; he uses ARP all the time. They should work beautifully for you.
Old Jun 27, 2009 | 03:22 PM
94 ls-r's Avatar
The only reason they would leak is cause the head or block are warped. Or they didnt use the arp lube and properly tork it. I have had them for years and never a problem.
Old Jun 27, 2009 | 03:30 PM
95 integra's Avatar
Yes, they stretch and let the head lift. I believe they revised them several years ago (like 00-01 era) but I've never had a problem out of OEM and I know several people making 500+whp on stock.
Old Jun 27, 2009 | 06:31 PM
Yeah, you're right. I was trying to remember what exactly the benefit was dealing with that.
They're nice too because the head gasket fits perfectly before you put the head on.
Old Jun 28, 2009 | 07:28 AM
95 integra's Avatar
Thats why you put your dowels in the block first, then put the HG on and then the head....that way everything lines up.
Old Jun 28, 2009 | 10:55 AM
racebum's Avatar
x2
Old Jun 28, 2009 | 06:00 PM
JDMInteg96's Avatar
if the headstuds themselves are leaking.. replace all the gaskets on the head studs lol...
Old Jun 28, 2009 | 06:02 PM
JDMInteg96's Avatar
ARP for life baby...
Old Jun 28, 2009 | 07:22 PM
paton5g's Avatar
I used OEM for my motor build. I see no reason to use anything else.
Old Jun 28, 2009 | 09:16 PM
TYPE-R#945's Avatar
maybe the head gasket is on wrong.....
Old Jun 29, 2009 | 01:42 AM
95DC2GS-R's Avatar
I don't see how they can leak, maybe if they weren't torqued down correctly and it would let the head lift. Stock head bolts are notorious for that, especially if they're reused.
You should be fine, I have never heard of any horror stories unless it was installation error. Also, AEBS head studs are great.
Old Jul 1, 2009 | 02:04 PM
snowpro127's Avatar
Thanks guys i think im gonna go with arp head studs
Old Jul 1, 2009 | 04:27 PM
94LS_allmota's Avatar
arp have to be torque down to 74+.maybe its torqued to oem honda head studs 62 pounds
Old Jul 3, 2009 | 05:22 PM
94 ls-r's Avatar
And the ARP lube must be used. It will affect the actual torque.
Old Jul 3, 2009 | 05:39 PM
Lord Helmet's Avatar
correction: 80 ft-lbs with arp assembly lube or 85 ft-lbs with 10-30w oil.
Old Aug 4, 2009 | 04:41 AM
chubb26's Avatar
New User
Does anyone know if there are different torque specs for arp head studs when you reuse them? Also what is the sequence? do you torque them from the center to outside?
( o )( o )
Jun 2, 2012 04:13 AM
Mike95lude
Aug 27, 2007 07:39 PM
IntegraMark
Feb 28, 2007 06:12 AM
9seccivicsi
Sep 20, 2004 10:55 AM
LsTurbo91
Apr 5, 2002 08:08 PM
