Apex V-AFC
Old Jun 22, 2001 | 09:15 AM
pstreck's Avatar
New User
Default Apex V-AFC
What have your guys experiences been with the Apex V-AFC on a GSR with exhaust intake header system, is it worth it to lower the vtec engagement point?
Old Jun 22, 2001 | 09:25 AM
bigTom's Avatar
Default Re: Apex V-AFC (pstreck)
simply... no... its not worth it.. honda made the motor and tuned it for the best hp it can get with its setup... r&d went into the vtec engagement point... changing it with stock cams will not do anything... or if it does... it wont be much... once u change internals is when ur motor motor is no longer stock therefore the tuning for it will be differant... hence where the v-afc comes into play.. even then... i still feel the v-afc is not worth the money
Old Jun 22, 2001 | 10:06 AM
Boba-Fett's Avatar
New User
If you take the car to a dyno and have someone that knows how to use it, it can be very beneficial.
Boba- who just bought a VAFC.
Old Jun 22, 2001 | 10:08 AM
Vazquez911's Avatar
Default Re: Apex V-AFC (Boba-Fett)
Car Go Fast With More Fuel = VAFC <-- Can give more fuel...
Boba - Who's spending too much money on toys... when does the Stook get anything, eh?
Old Jun 22, 2001 | 10:09 AM
Boba-Fett's Avatar
New User
Default Re: Apex V-AFC (Vazquez911)
hahhaahaha
Boba- who thinks Vazquez911 needs to get an s2k.
Old Jun 22, 2001 | 10:10 AM
Vazquez911's Avatar
hahhaahaha
Vazquez <--- Who's going to kick some **** if he lets the masta plan out of the bag.
Old Jun 22, 2001 | 10:11 AM
Boba-Fett's Avatar
New User
SSHhhhhhhhhhhhh, beeee very very qquite, I'm hunting Domestics.
Boba- who can beat most stock domestics in his ITR.
Old Jun 22, 2001 | 10:32 AM
Vazquez911's Avatar
Heeeeeeerreeeee. V8 V8 V8 V8 V8...
Old Jun 22, 2001 | 01:41 PM
SystemGSR's Avatar
Not true, I know sombody who gained 8WHP by removing 4 or 5 psi of fuel pressure. More fuel does not mean more power, not unless the car is running very lean anyway. Most of the time with I/H/E you need to remove some fuel up top.
My advice, If your goign to get cams, gears, FPR, etc then yes get the vafc now if you got a hell of a deal on it like i did, but if you are going to pay say 340 for it then you might just want to spend/save you money for cams or whatever until then...
Old Jun 22, 2001 | 01:42 PM
Vazquez911's Avatar
Default Re: Apex V-AFC (SystemGSR)
Good eyes.. that's why I said CAN GIVE... if need be... more importantly it balances out the fuel curve for the best possible gain, whether it be a raise in lower of fuel.
excluded
Oct 17, 2003 09:38 AM
spooned out
Aug 25, 2003 06:31 PM
KevinOhlin
Mar 10, 2003 06:06 PM
Quick_lude
May 18, 2002 11:53 PM
hondafrk
Feb 23, 2002 07:08 PM
