antenna problem
Old Jun 24, 2007 | 09:28 PM
JDMmovement's Avatar
Default antenna problem
i got a 01 integra ls coupe. my problem is that my antenna doesnt go down..i would hear the motor run when i turn the radio on, but nothing happens. i dont want the mast to stay up all the time...so is there anyway that i can lower the mast and leave it there?.
Old Jun 24, 2007 | 09:29 PM
Lauj87's Avatar
Default Re: antenna problem (JDMmovement)
yeah mine dose the same...it's borken your gunnna need a new one lol. not much help but im planning on removing it completely and getting a different one.
Old Jun 24, 2007 | 09:36 PM
Default Re: antenna problem (Lauj87)
i just wanna know how to lower the mast for the time being.
Old Jun 24, 2007 | 10:22 PM
DA9_DAD's Avatar
you can't lower the mast unless you remove the entire unit from the car and cutting the plastic teeth off from inside the mast. then replace the unit back in..but if your going to go through all that trouble, dude, just buy another mast. Ebay has them for like 15.00 shipped if your lucky and oem. its an easy job. the only thing is that you will have to remove the broken piece thats coiled inside the unit. just remove the metal cover and take out the broken piece.
Old Jun 24, 2007 | 11:07 PM
Default Re: antenna problem (DA9_DAD)
aite..thanks a lot man.
Old Jun 25, 2007 | 05:11 AM
Dogginator's Avatar
Daisy... Daisy...
Turn off the radio and push down on the mast as the motor is trying to lower it. It should lower pretty easily. Disconnect the power connector behind the trunk lining to keep it down.
Old Jun 25, 2007 | 05:50 AM
Default Re: antenna problem (Dogginator)
ill try it out..if it doesn't work..ima order one off ebay.
Modified by JDMmovement at 10:50 AM 6/25/2007
Old Jun 25, 2007 | 10:42 AM
alexisthemovie's Avatar
if yours is stuck up, just use force to shove it down. you can pull it back up later if you want.
Old Jun 25, 2007 | 11:09 AM
DA9_DAD's Avatar
Default Re: (alexisthemovie)
if its stuck or jammed; and if pushed, too hard it will bend...then he's fck'd. then he'll have to go buy another.
Old Jun 25, 2007 | 12:21 PM
exies's Avatar
Default Re: (DA9_DAD)
I also believe the antenna requires power to operate properly. I had this problem too. I pushed the antenna down and disconnected the power. The radio stations became unclear and full of static.
I just plugged it back in and am currently dealing with the noise again.
Old Jun 25, 2007 | 01:17 PM
Default Re: (exies)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exies &raquo;</TD></TR><TR><TD CLASS="quote">I just plugged it back in and am currently dealing with the noise again.</TD></TR></TABLE>
i think you need a new one lol.
mr devious illusions
Jan 20, 2007 01:14 PM
ricehero
Jan 11, 2006 07:41 AM
Crasian
Sep 3, 2005 07:08 PM
jerry5150
Jun 13, 2005 12:05 PM
Yell00ITR
Apr 11, 2004 09:50 PM
