Another problem!
Old Dec 22, 2006 | 06:16 AM
RS'R''s Avatar
Default Another problem! Slipping sound...
There is a slipping sound, like a slipping belt when the car begins to pull from a stop, or low 2nd gear. The slippage stops once the engine gets above 2k or so and then the car really picks up. I don't think its the clutch because it won't slip under hard acceleration. I also put the hand brake on and engaged the clutch for a bit, no sound... Once the engine warms up it happens less often.
Any ideas? Thanks.
Modified by Teg'R'S at 7:58 AM 12/22/2006
Old Dec 22, 2006 | 08:09 AM
95 integra's Avatar
Default Re: Another problem! Slipping sound... (Teg'R'S)
Accessory belt, it sounds as if one of them is too tight. I had problems getting my tensions right the first time I replaced my belts, too tight and they squeal at start up/when its cold, too loose and they slip and squeal when the engine is warm.
Old Dec 22, 2006 | 08:14 AM
RS'R''s Avatar
Default Re: Another problem! Slipping sound... (95 integra)
I hope its that
Modified by Teg'R'S at 11:20 AM 12/22/2006
Old Dec 22, 2006 | 10:21 AM
RS'R''s Avatar
I just went to check the tension on all the belts. Which one is the accessory belt?
caliEJ8
Jan 26, 2016 02:26 PM
lithium_mt
Nov 26, 2012 03:06 PM
JDM00SI
Feb 13, 2005 06:45 PM
hondacrxflyer
Dec 3, 2004 07:29 AM
Rydaddy
Jan 6, 2003 07:51 AM
