Is another location for knock sensor
Old Sep 8, 2008 | 04:54 PM
4drteg54321's Avatar
Default Is another location for knock sensor
Block:
LS B18A1
OK i forgot to drill a place for a knock sensor when i had the motor out if there another spot i can put it??
Old Sep 8, 2008 | 05:06 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: Is another location for knock sensor (4drteg54321)
Honda put it between cyl 2 and 3 for good reason. There is no other good spot to put it in relation to the cyliders, where it should be.
Tap and install the KS in the blank on the back side of the block
Sucks you installed the motor already
gabrielsousa
Nov 4, 2015 04:12 PM
eddisgetti1
Nov 12, 2011 09:45 PM
hondakrazy
Nov 14, 2008 10:42 AM
monty Si-R
Apr 25, 2007 05:26 PM
KURUPTinc
Jun 22, 2005 11:03 PM
