airbag cover change(for different color)???
i'm about to swap out 97' airbags for 94' ones and want to know if i can remove the cover from the 94' airbags and clip them onto the 97' airbags????
* B A N N E D *
Re: airbag cover change(for different color)??? (lmike6453)
i told you in your other thread...you can't swap 97 to 94 unless you redo the clockspring and srs harness assembly
Re: airbag cover change(for different color)??? (jhammond_82)
yeah there plugs are different if you swap the entire airbag. I found that out when i did my tan to black conversion. What i did was keep my old airbag and swapped the top cover. The bolts were kind of different but still fit.
04yfz
01-10-2009 11:38 AM
Turbolude
03-14-2002 06:16 AM
