after upgrades my track time decrease!!
Old Mar 31, 2006 | 11:34 PM
tomlinson619's Avatar
Default after upgrades my track time decrease!!
before i had a stock gsr motor with IHE and i hit a 9.9 at a 1/8 track with just bolt ons and burnt clutch. now with my new set up i added ctr cams and manifold and a 6 PUCK ACT clutch. my new time is now 10.5 WTF!! i cannot launch with this 6 puck and when i shift to 2nd i spin out alot.. not catching traction.. thinking about getting rid of this 6 puck and use a street disk. any thoughts? suggestions?
Old Mar 31, 2006 | 11:48 PM
PickleTeg's Avatar
Default Re: after upgrades my track time decrease!! (jdmb18ckid)
I think that 6 puck is too much for what you are running...just an idea....my bottom of the line ACT holds 243 ft/lbs.....
Old Mar 31, 2006 | 11:49 PM
elrandeeto's Avatar
did u get it tuned with the ctr cams if not that would hurt your time also what are your 60fts before and after
i agree the 6puck is a little to much
Old Mar 31, 2006 | 11:50 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: after upgrades my track time decrease!! (PickleTeg)
My friend is from sierra vista.
Old Apr 1, 2006 | 03:36 AM
IHTFP's Avatar
you need to get your motor tuned with the new cams and learn to drive your new clutch...
your times will decrease as soon as you learn to drive
Old Apr 1, 2006 | 04:09 AM
tegman85's Avatar
ive got the 6 puck clutchnet. it was a big jump from stock. you just have to get used to it. took me a while, but couldnt go back now
Old Apr 1, 2006 | 07:08 AM
Dogginator's Avatar
Daisy... Daisy...
Is your VTEC crossover still set at 4400 RPM using the CTR cams? If so, you should feel a considerble torque loss from 4400 RPM until about 5200 RPM.
As mentioned bt IHTFP, you need to tune your motor for the changes. The VTEC crossover is the most critical at this point.
Old Apr 1, 2006 | 10:34 AM
Default Re: after upgrades my track time decrease!! (Dogginator)
i ran my friends p72 chipped ecu vtec xover at 5700 but i really think the 6puck is what got my time so high
Old Apr 1, 2006 | 11:08 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmb18ckid &raquo;</TD></TR><TR><TD CLASS="quote">before i had a stock gsr motor with IHE and i hit a 9.9 at a 1/8 track with just bolt ons and burnt clutch. now with my new set up i added ctr cams and manifold and a 6 PUCK ACT clutch. my new time is now 10.5 WTF!! i cannot launch with this 6 puck and when i shift to 2nd i spin out alot.. not catching traction.. thinking about getting rid of this 6 puck and use a street disk. any thoughts? suggestions?</TD></TR></TABLE>
better tires, this was my problem i was pulling 9.9 with busted mounts and a 14 year old slipping clutch...and i had old all-season tires. when i installed the new clutch and mounts i was only able to get a 10.1 because i was launching pretty good...(as well as could be expected on old tires), but i was spinning all of second and some of third.
Old Apr 1, 2006 | 07:36 PM
b20integrapower's Avatar
Default Re: after upgrades my track time decrease!! (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">
better tires, this was my problem i was pulling 9.9 with busted mounts and a 14 year old slipping clutch...and i had old all-season tires. when i installed the new clutch and mounts i was only able to get a 10.1 because i was launching pretty good...(as well as could be expected on old tires), but i was spinning all of second and some of third.</TD></TR></TABLE> shouldnt new tires, clutch and mounts yield better times? how did your time increase?
Old Apr 1, 2006 | 10:42 PM
projectTeG's Avatar
Default Re: after upgrades my track time decrease!! (b20integrapower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote"> shouldnt new tires, clutch and mounts yield better times? how did your time increase?</TD></TR></TABLE>
i had old tires and new mounts and a clutch, when my clutch was slipping it would break my tires loose so i would still accelerate strong, but with the new clutch on the old tire i had problems through all gears with traction
Old Apr 3, 2006 | 11:37 AM
PickleTeg's Avatar
Default Re: after upgrades my track time decrease!! (Kind_of_a_big_deal)
I am sorry for him LOL
S@nt0s
Feb 27, 2011 08:40 PM
tomlinson619
20
Apr 12, 2006 02:19 PM
LSVTEC 91 Civic
May 20, 2005 04:31 PM
CivicTypeR00
Jun 9, 2004 08:47 PM
rbf351
Jul 29, 2002 10:29 AM
