AEM Intake Issue
Old Dec 4, 2004 | 10:53 AM
kimo98GSR's Avatar
Default AEM Intake Issue
I have a 98 GSR with an AEM Cold Air Kit installed. I have noticed that I have an issue with the intake rubbing on the a/c line. The a/c low pressure return line and the cold air piping is rubbing a hole in the a/c line and the a/c line is rubbing a hole in my intake piping.
My question is this: Is other HT people having (or had) this issue? If there a fix for this issue, or did someone sell me the wrong kit?
I looked on the archives and couldn't find anything.
Old Dec 4, 2004 | 11:12 AM
EKboyEK96's Avatar
Default Re: AEM Intake Issue (kimo98GSR)
get it cleaned or clean it yourself.
Old Dec 4, 2004 | 01:42 PM
Kendall's Avatar
I had the same issue, but I ended up selling the intake, cutting out my passenger side high beam light and running a custom ram air setup. I didn't have the problem anymore.
Old Dec 4, 2004 | 06:31 PM
kimo98GSR's Avatar
Default Re: (Kendall)
I was hoping that there was another option than get rid of it and create a custom intake. I like the AEM, but that might be my option, I don't want to get holes in my a/c lines.
Old Dec 6, 2004 | 09:38 PM
kimo98GSR's Avatar
Default Re: (kimo98GSR)
bump...
Old Dec 6, 2004 | 09:43 PM
purplegsr's Avatar
I never had that problem, although I heard about it. My intake piping made contact with the a/c line, but did not wear a hole in it. I would try putting washers/spacers on the brackets that attach the intake arm to the car. By moving the mounting point a bit higher, you may be able to avoid or lessen the rubbing. I would try to loosen up some of the brackets and clamps and reposition them as much as possible before giving up - good luck!
Old Dec 6, 2004 | 11:49 PM
joek84's Avatar
Default Re: (purplegsr (Exospeed))
you could put a piece of rubber between where they touch
SickSpeed06Si
Honda Civic (2006 - 2015)
10
Jun 22, 2006 11:57 AM
jrow87
14
May 18, 2004 01:53 PM
williamdte
May 9, 2004 12:52 AM
7808
Sep 11, 2003 12:55 PM
SpoonFed
Jan 31, 2002 05:43 PM
