AEM CAI problem...
Old Sep 13, 2001 | 01:10 PM
redGSRguy's Avatar
Default AEM CAI problem...
Hi guys I recently got a 98gsr and also an AEM CAI
I'm currently at a friends house trying to put it in, i finally got the stock air box out, but when taking off the breather hose/water hose assembly in step 2b this green stuff started to come out of where i disconnected the tupe from the throttle body. It's greenish and very hot, is this normal? What should I do?
Old Sep 13, 2001 | 01:35 PM
troy00gs's Avatar
New User
Default Re: AEM CAI problem... (redGSRguy)
It is antifreeze. It is perfectly normal. Just wait awhile for your car to cool down. Try to swap the hoses as fast as possible to aviod as much leakage as possible.
Old Sep 13, 2001 | 02:00 PM
redGSRguy's Avatar
Thanks Troy, i'll go try that now
-jackson
Old Sep 13, 2001 | 02:05 PM
Tanner's Avatar
New User
Also if you let much of this "green hot stuff" leak out you might want to check the level of "green stuff" in the radiator, but make sure your car is cool before removing the radiator cap....
Old Sep 13, 2001 | 02:49 PM
GTEater's Avatar
didn't it say in the directions to drain some of the coolant before the install?......i remember thats what it said in my directions, but i wondered why i would need to do this......then the say thing happened to me when i removed that hose.......guess i should always follow directions
Old Sep 13, 2001 | 04:56 PM
H23 Power's Avatar
Default Re: AEM CAI problem... (GTEater)
i personally never removed that hose...there is no need to
Old Sep 13, 2001 | 05:32 PM
redGSRguy's Avatar
I didn't see where it said to drain some coolant, but maybe i just didn't read it all the way through, finally managed to get it on and it sounds great, thanks for the info guys.
Old Sep 13, 2001 | 07:38 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
YOU BE SOFA KING WE TODD DID
Old Sep 13, 2001 | 07:39 PM
B00ST2nR's Avatar
it did say to wait for your car to be COMPLETELY cooled and stopped running before trying to install the AEM CAI... anyways... good luck, and you'll love the way your car runs after the CAI is installed... have fun!
Old Sep 13, 2001 | 08:42 PM
X2BOARD's Avatar
Default Re: AEM CAI problem... (GS-Racer)
If my memory serves me correctly....and I AM low on brain cells... the instructions do say to drain some coolant....but that ain't necessary....
Suck it up and finish the install daniel son.....
Let's get to the **growllllll**
Old Sep 13, 2001 | 09:05 PM
redGSRguy's Avatar
Default Re: AEM CAI problem... (Dave-ROR)
obviously, our member Dave-ROR has a speech impairment problem.
Old Sep 13, 2001 | 09:08 PM
SuprFleaJQ's Avatar
New User
apparently, he does.
keck
Apr 19, 2003 02:51 PM
EJ8 Kenobi
Mar 22, 2002 09:54 PM
SpoonFed
Jan 29, 2002 06:10 AM
Toda Party
Jul 16, 2001 04:20 AM
