Adjusting valves?
Old Nov 10, 2006 | 07:25 AM
str8JDMteggy's Avatar
Default Adjusting valves?
Recently put in omni valves, portflow dual valve springs and retainers and i was told to not run my car without adjusting the valves to spec or the valves will burn out. How do i adjust the valves?
Old Nov 10, 2006 | 07:37 AM
BLacK FirE's Avatar
Default Re: Adjusting valves? (str8JDMteggy)
http://www.c-speedracing.com/h...t.php
or
http://www.team-integra.net/se...D=485
Old Nov 10, 2006 | 09:25 AM
95 integra's Avatar
Default Re: Adjusting valves? (BLacK FirE)
The valves are gonna burn out? Interesting.....
Old Nov 10, 2006 | 12:22 PM
Honda Hick's Avatar
Did you put in the valve springs or did someone else?
When they were installed the valves should have been adjusted. You could run into some problems if the valves clearance are way too loose (valves won't open enough) or way too tight (valves might not close all the way).
Old Nov 10, 2006 | 02:03 PM
thanks looks like im off to purchase the needed tools.
junkyard racer
Sep 7, 2008 04:41 PM
BigPlansNoMoney
Nov 2, 2004 06:45 PM
