Adjusting distributor timing
Old Jun 26, 2009 | 01:36 PM
azzurribaggio's Avatar
Default Adjusting distributor timing
So the other day I took my distributor off to check my ignition coil inside....never made it that far since I couldn't get the stupid rotor off due the screw looking kinda stripped. So I figured I'd scuff up the cap and rotor contact points a bit while they were accessible with some sandpaper. Well I never made a mark as to how the distributor was lined up and so now I think my timing is off. I actually put the distributor back in the wrong way since it wouldn't start for a while and I figured I was not at #1 cylinder at DTC. So I put it back in correctly but now it's starting albeit running super rough and eventually dies. In order to check the timing I need the car to idle on it's own, so do I rotate the distributor clockwise (if facing it from the passenger front fender), I assume advancing the timing, to where there is a gap to the right of the top washer/bolt assembly???
HELP!
Old Jun 26, 2009 | 09:25 PM
boosteddohczc's Avatar
Default Re: Adjusting distributor timing
thats retarding your timing you have to rotate it towards the firewall to advance it but to me it sounds like you have your firing order wrong. what year and what model is your car??
MastaFlyMason
Oct 2, 2016 02:53 PM
honda_crv_2000
Honda CR-V & Element
Jan 16, 2015 01:14 PM
95civhb
Aug 14, 2010 06:51 AM
96a-ccord
Feb 26, 2010 02:04 PM
azzurribaggio
Jun 26, 2009 05:07 PM
