ABS Removal Help
Looking into removing my ABS system for non ABS. Now I know how to remove it and etc etc. Just need help in which proportioning valves I can use. Other than the Integra RS proportioning valve, is there any other prop valves I can use that may also use the stock RS brake lines? If not are there any prop valves I can use instead of the RS?
Any input is appreciated. Thanks.
What year is your Integra?
94-97: What you need is 46310-ST7-A00 PIPE A BRAKE, 46320-ST7-A00 PIPE B BRAKE, 46321-ST7-A00 PIPE H BRAKE, 46360-SR3-A02 PIPE F BRAKE, and a prop valve from any Civic/CRX/Del Sol 88-95 or Integra 92-97 that did not have ABS but had 4 wheel disks(you want a 4040 valve). If you keep the 1' ABS master you need to transfer the M12x1.0 fitting from the old line to the new pipe B line. Some bending is needed.
98-01:46310-ST7-A11 PIPE A BRAKE, 46320-ST7-A11 PIPE B BRAKE, 46321-ST7-A11 PIPE H BRAKE, 46360-ST7-A11 PIPE F BRAKE and a prop valve from a 96-00 Civic(doesn't matter which one, they all work the same) or 98-99 Integra RS.
Wdpfreak145
10
Mar 28, 2013 10:48 AM
743power
Apr 23, 2003 03:19 PM
46310st7a11, 46320st7a00, 46321st7a00, 92, 97, abs, acura, integra, m12x10, proportioning, removal, remove, system, valve
