ABS light on and off
I was driving to school in the morning and i was in 4th gear at 3k rpm and all the sudden the abs came on and right before it turned off the rpm droped 1000 rpm then the light went off then the rpm came back to normal. Eversince that the abs light never came on should i be worry ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by __oversea »</TD></TR><TR><TD CLASS="quote">i dont think you can't pull the code, unless light is on. different story by using scanner.</TD></TR></TABLE>
You certainly can on a Gen 3. They store the last three codes. The paperclip method works.
