ABS DALEMA HELP!!!!!
LAst nite while driveing my car i noticed my ABS light on, then i relized its been on for a day or so. I swap the motor 2 weeks ago and this NOW happens any ways, i check the ABS fluid, IT was EMPTY. i pour some in. 5 seconds later i hear it leaking,to the ground, from the left near the radiator, . the problem is below the battery and above the cross member. PLEase help explain what happen. and how to fix
sounds to me like you've got a broken brake line.
In that case, I'd save myself the headache, take it to a dealership, and just let them fix the line.
Unless you are good with bending brake lines. Then by all means go for it. That's probably the hardest part about it.
check Aucra Auto Parts out. They may sell pre-bent lines for you. Then all you'll have to do is remove the old one, install the new one, and bleed the brake system.
That is, of course, assuming that it is a line that is broken.
P.S. It's not safe to drive it with faulty brakes.
Wdpfreak145
10
Mar 28, 2013 10:48 AM
