ABS CONVERSION?.....
Old Jan 11, 2004 | 06:01 PM
808dc2's Avatar
Default 94-97 to 98+ ABS CONVERSION?.....HELP!
I'm in the process of putting a jdm itr front end conversion w/ oem H.I.D.'s onto my 94gsr. My problem is that the ABS modulator on the 94-97 integra GSR's is to big to allow enough room for the jdm itr oem H.I.D. ballasts. Since I don't want to lose ABS or remount the oem ballast I was wondering if anybody on here could tell me what parts I would need to convert my 94 ABS unit to the smaller 98+ ABS unit?
I know I will need a 98+ ABS modulator which I already have. I will also need 98+ ABS front hard lines. Is there anything else I will need to do the 94-97 ABS to 98+ ABS conversion?
Will I need a different mounting bracket for the 98+ ABS modulator?
Old Jan 11, 2004 | 06:51 PM
808dc2's Avatar
Default Re: 94-97 to 98+ ABS CONVERSION?.....HELP! (808dc2)
up
Old Jan 11, 2004 | 09:47 PM
808dc2's Avatar
Old Jan 11, 2004 | 10:23 PM
DIY's Avatar
DIY
free bump
Old Jan 12, 2004 | 01:10 PM
dwolsten's Avatar
Don't bump your message in the same day. If you must, at least wait a day or two; most people aren't online 24x7.
Anyway, you do need a new mounting bracket to mount the ABS pump. They're not the same. Whoever sold you the 98-01 pump should have included this.
I'm not so sure you need new hard lines; it may be possible to bend the old ones into place. Anyone have any advice on bending brake lines?
You probably need a new ABS computer; they're different, and probably designed for the particular pump that's installed.
Some other items that are different between the generations: brake master cylinder and possibly the proportioning valve. I don't know if these would affect the ABS or not.
Old Feb 19, 2004 | 06:20 PM
808dc2's Avatar
Default Re: 94-97 to 98+ ABS CONVERSION?.....HELP! (dwolsten)
can I switch my 94 ABS modulator to a jdm +98 properly without changing my exsisting ABS computer?
I already have the mounting bracket for the newer ABS modulator and can get the newer abs front hardlines.
Old Feb 19, 2004 | 06:54 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I think the newer one might have a different number of channels or something like that, I'm not sure. You will most likely need the computer to go with it.
Cheapshot1979
Suspension & Brakes
Apr 4, 2014 10:18 AM
-__-
Jan 24, 2014 12:46 PM
DC2 to AP2
Oct 12, 2009 04:08 PM
hmongyaj87
Apr 18, 2007 10:30 AM
SiRTifiedacc
Dec 15, 2005 12:14 AM
