abs code 2 1 (parking brake)
Old Apr 6, 2011 | 05:27 PM
95BG33PGSR's Avatar
Default abs code 2 1 (parking brake)
where in the hell should i start? the only thing that i know of that is not right is my parking brake light is burnt out...i reset the abs unit yesterday and my light didnt come on all the way home or on the way to work this morning...but on the way home today it showed up again...where/what do i even check?
please help me out, i cant find an answer anywhere
Old Apr 7, 2011 | 05:57 AM
fcm's Avatar
fcm
Old Fart
Default Re: abs code 2 1 (parking brake)
I would start by replacing the parking brake light, also check brake fluid level and check the operation of the brake fluid level float in the reservoir. 94
Old Apr 7, 2011 | 07:45 AM
95BG33PGSR's Avatar
level is good, how do i check the float? and how would that be throwing an ABS code(parking brake) if the float is bad im going to check the actual e-brake sensor today, if it does turn out to be bad, who knows how long it's been bad cause my brake light bulb(in the dash) has been hurnt out forever
Old Apr 7, 2011 | 11:10 AM
fcm's Avatar
fcm
Old Fart
Both the hand brake, [e-brake] switch and the brake fluid level switch supply a ground to the hand brake warning light.
To test the brake fluid level switch, unplug the plug that goes to brake reservoir lid, connect a multimeter to the two terminals of the lid plug, [lid side] set meter to continuity, move the float up and down on shaft, meter should show continuity only when float is at bottom of shaft, [low brake fluid].
The hand brake switch is a simple grounding switch, should only ground out when handle is up.
You could also just replace the warning bulb and see if it turns on and off when you use the hand brake and unscrew the reservoir lid.
The above may not be your problem, but until you eliminate them, you can't know for sure. 94
Old Apr 9, 2011 | 02:56 AM
95BG33PGSR's Avatar
hey man i got it all fixed thanks for the help bud!
Old Apr 9, 2011 | 06:24 PM
fcm's Avatar
fcm
Old Fart
So tell everyone what was wrong, so someone searching can check and see if they have the same problem. 94
Old Apr 10, 2011 | 03:54 AM
95BG33PGSR's Avatar
my problem ended up being either the bulb or my actual reservoir cover...my connections were pretty corroded and the float was slightly sticking
Don Drift
Jan 10, 2017 08:35 PM
supermotothud
Nov 10, 2008 04:09 PM
ceyazzie
May 11, 2007 04:48 PM
mikester_91
Jan 18, 2005 01:14 PM
FK00GSR
Nov 7, 2003 12:32 PM
