about the comtech icebox...
Old Jun 30, 2004 | 12:07 AM
taffetawhitegsr's Avatar
Default about the comtech icebox...
can i just buy the comtech ice box and use my stock GSR intake arm with a k&n filter and get near the same gains as i would with the comptech short ram and icebox? dont wanna waste money on ne thing i dont need.
Old Jun 30, 2004 | 12:32 AM
AK94GSR's Avatar
Default Re: about the comtech icebox... (taffetawhitegsr)
i havent heard about people doing this but email comptech, they should know
Old Jun 30, 2004 | 12:53 AM
aeon's Avatar
i've heard of people using the stock arm but i dunno about using it with the K and n filter.
Old Jun 30, 2004 | 02:33 AM
Dc2 Powered's Avatar
i heard you could only use a stock arm if you have an ITR arm
Old Jun 30, 2004 | 06:52 AM
timmy8151's Avatar
Default Re: (Speedin Type R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedin Type R &raquo;</TD></TR><TR><TD CLASS="quote">i heard you could only use a stock arm if you have an ITR arm </TD></TR></TABLE>
Nope, you can use the stock arm on any model.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeon &raquo;</TD></TR><TR><TD CLASS="quote">i've heard of people using the stock arm but i dunno about using it with the K and n filter.</TD></TR></TABLE>
If the filter fits the stock box, then it will fit the Icebox. So you could use the K&N E-2427 drop in filter.
Old Jun 30, 2004 | 07:03 AM
mrmonk's Avatar
Default Re: (timmy8151)
not trying to jack teh post.. but is a bigger filter necessarily better? because my filter that came with my Injen SRI is small as **** compared to the aem or k&n.
Old Jun 30, 2004 | 07:18 AM
95 integra's Avatar
Default Re: (mrmonk)
I used the icebox with my factory intake arm and factory filter. I suggest you use either the K&N or a factory filter, anything else isnt going to fit right in the box, nor is it going to seal properly around the box. BTW, you have to use a intake arm that works with your car(LSs can use ITRs or LS arms, GSRs have to use GSR arms).
Old Jun 30, 2004 | 07:21 AM
timmy8151's Avatar
Default Re: (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">I used the icebox with my factory intake arm and factory filter. I suggest you use either the K&N or a factory filter, anything else isnt going to fit right in the box, nor is it going to seal properly around the box. BTW, you have to use a intake arm that works with your car(LSs can use ITRs or LS arms, GSRs have to use GSR arms). </TD></TR></TABLE>
Correct. I'm currently using the Comptech foam filter in my Icebox and the ITR OEM arm on my LS.
Old Jun 30, 2004 | 10:35 AM
redman223's Avatar
Which box do you have? Is it for the LS or the ITR? Did the icebox come with a filter or did you buy that seperately?
I have a GSR with a Skunk2 IM, so I will need the ITR arm, and the box for the GSR or the ITR?
Old Jun 30, 2004 | 07:16 PM
timmy8151's Avatar
Default Re: (redman223)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redman223 &raquo;</TD></TR><TR><TD CLASS="quote">Which box do you have? Is it for the LS or the ITR? Did the icebox come with a filter or did you buy that seperately?
I have a GSR with a Skunk2 IM, so I will need the ITR arm, and the box for the GSR or the ITR?</TD></TR></TABLE>
IIRC, the box is the same for all models, but you should contact Comptech to be sure. The filter comes seperately and costs about $60 and is reusable.
Old Jul 1, 2004 | 11:18 PM
LsNer00's Avatar
so is there a big difference in using a after market arm, im just using the stock arm(ls) with ice box, for now unless its worth the money to get the arm also.
Old Jul 2, 2004 | 12:13 AM
Seedc2's Avatar
Default Re: (LsNer00)
I think the comptech intake arm is just bling. Im using it with stock intake rubber arm and drop in k&n filter e-2427.
comptech filter is sold separately. (50-70$ for the foam filter) EEK
if you have a skunk2 IM you'll need the itr rubber intake arm and I believe all iceboxes are universal fit for all model integras
Old Jul 2, 2004 | 07:37 AM
95 integra's Avatar
Default Re: (kendogg)
actually the mounting brackets for the GSR and the ITR/LS are different. I know these from experience, I had to custom make my mounting brackets because the ones that came with mine were for the ITR/LS.
ITR-965
Mar 27, 2007 02:58 PM
.water
Aug 25, 2005 11:22 PM
dc2comptech
Feb 18, 2004 01:13 PM
95TEG
Aug 21, 2003 12:17 AM
yellow blur
Apr 7, 2002 11:12 PM
