99 Integra Mod
Old Apr 24, 2009 | 11:41 PM
I Still Love H.E.R.'s Avatar
Default 99 Integra Mod
When i bought the car my antenna wouldnt go down, so i decided that i wanted to just remove it. Can i just take the antenna out without removing the whole assembly and just putting a grommet to cover the hole?
Old Apr 24, 2009 | 11:48 PM
sp00ledbseries's Avatar
Default Re: 99 Integra Mod
ya but that is ghetto as ****
Old Apr 25, 2009 | 12:49 AM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Nice screen name. You can remove the antenna and replace it with one from a S2000. Looks clean and oem. I suggest that.
Old Apr 25, 2009 | 11:39 AM
mouab18c1's Avatar
its pretty simple actually, i took out the whole thing in less then ten minutes. and plugged it with a cap i bought at home depot.
Old Apr 25, 2009 | 11:43 AM
S2Integra's Avatar
honda jdm hole plugs exists for thins car, cant remember webstite. anyway there expensive compared to ones frfom home depot. Also you can get a new antenna mast motor.
www.OEMAcuraparts.com
www.Acuraoemparts.com
Old Apr 25, 2009 | 12:41 PM
mouab18c1's Avatar
i bought mine for how many cents? i forgot but i just sprayed it to my car color
Old Apr 25, 2009 | 06:02 PM
mattyrocks785's Avatar
i got a firewall plug from a dude on my local forums. kinda overpayed but you could get it for like 5$ at a junk yard and it works great. honestly dude either just replace the mast or remove the motor too. its not that hard.
Old Apr 25, 2009 | 06:08 PM
DAintegraGSR's Avatar
^^ def bro, might as well remove the motor as well, def not hard an takes about 10-15 minutes, or just go w/ s2.. looks great
Old Apr 25, 2009 | 06:11 PM
I was searching about this and i saw a pic of of someone buying a grommet from Honda and using that to plug his antenna hole...It looked pretty clean and is fairly cheap.
Old Apr 25, 2009 | 07:12 PM
95LS1t's Avatar
it's really easy to take off lol, just pull the panel and everything unbolts
i have an s2k antenna on my car now, idk why but it sucks. i'm looking into where else i can put the antenna on my car and still have it functional, the EG setup looks pretty good
Old Apr 25, 2009 | 07:51 PM
a97b18b's Avatar
shark2 antenna ftw!!
Old Apr 26, 2009 | 08:50 AM
do you guys have any pics of these different antennas by any chance? Or a tutorial on how to take it off?
Old Apr 26, 2009 | 10:00 AM
LOVEthatDC2's Avatar
i just smashed mine down haha
hold it with a pair of plyers and hammer it GENTLY into the assembly
Old Apr 26, 2009 | 10:28 AM
kronikSLOW's Avatar
ok ok heres your tutorial on the simplest thing ever. get all the crap out of your trunk. get yourself a 10mm socket on an extension and a flat head. push those little plastic circles down and they will release the plastic that covers your trunk. start with the tail first then the left side. next put the seats all the way forward. theres a pop out cover with a 10mm behind it take that out. theres another 10mm above the wheel well take that out. disconnect the trunk light. pop that cover off and unbolt the electrical connectors to the motor then unbolt the motor. i may have forgotten something i did this a while ago. and for like 2.50 i bought my plug from honda i think its 31mm not sure though but i think its the plug from the tl a pillar.
Old Apr 26, 2009 | 06:04 PM
jhammond_82's Avatar
Reject Papi
http://cgi.ebay.com/ebaymotors/OEM-I...Q5fAccessories
Old Apr 27, 2009 | 12:21 AM
lol firewall plug. thats what i have. i love the way they sell them as antenna deletes when there are actual honda parts for a proper antenna delete. not JUST the genuine honda firewall plug.
Old Apr 27, 2009 | 12:47 AM
Hydro_Da's Avatar
that plug is wayyyy over priced.
op shoot me a pm and ill send you the part number, you can get it at your local honda dealer for like 5-6 bucks and it looks clean.
i have my rear wiper and antenna deleted and paid less then 12 bucks for both grommets.
if you still want to listen to your radio there's a thread around here about an antenna you mount to the glass inside your car, ill try to find it.
DTMamg
Jul 2, 2010 10:15 PM
sobey
Mar 4, 2009 07:06 PM
triple
Honda S2000
Apr 26, 2007 05:59 PM
mr devious illusions
Jan 20, 2007 01:14 PM
jolt-tsp
Oct 31, 2003 07:30 PM
