98 + up frontend conversion
Old Oct 8, 2003 | 07:42 PM
  #26
VTECorona's Avatar
Default Re: 98 + up frontend conversion (Type R Driven15)
I agree, I personally would rather dump 3 grand into a turbo then having a JDM front end which is hardly unique anymore.
Old Oct 8, 2003 | 07:46 PM
  #27
patdemps's Avatar
Default Re: 98 + up frontend conversion (VTECorona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona &raquo;</TD></TR><TR><TD CLASS="quote">I agree, I personally would rather dump 3 grand into a turbo then having a JDM front end which is hardly unique anymore.</TD></TR></TABLE>
very true. its going to become rare to see tegs w/o a jdm front in a few years. i dont think its worth the money it costs, so many other things you could do
Old Oct 8, 2003 | 08:03 PM
  #28
N1NjA TuRtLE's Avatar
Default Re: 98 + up frontend conversion (Swift_asian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swift_asian &raquo;</TD></TR><TR><TD CLASS="quote">what u need
-bumper
-headlights
-corner lights
depends on the condition of the front end.... i seen them go anyware from 300-500</TD></TR></TABLE>
whoa that's it, i tohught maybe u needed a new hood and fenders also. Ahh cool.
Old Oct 8, 2003 | 08:38 PM
  #29
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 98 + up frontend conversion (ReX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReX &raquo;</TD></TR><TR><TD CLASS="quote">
Negative, unless by headlights you mean the bulbs. Bulbs are the same size. Housings are not interchangable.</TD></TR></TABLE>
Actually the only difference between the headlights is the clear cover on the front. The rear housing and insides are exactly the same for all Integras. They are interchangeable, BUT where would you find only the clear covers? Probably not anywhere.
My passenger side headlight actually has the projector and inside pieces from a 98+ headlight that was broken on the outside. I broke the projector shield inside mine, so the I just swapped in the 98+ projector housing, which I got for free from a bodyshop. They had pulled it off of an Integra that had been in a slight fenderbender and was also getting the JDM front.
Old Oct 8, 2003 | 08:41 PM
  #30
VTECorona's Avatar
Default Re: 98 + up frontend conversion (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
Actually the only difference between the headlights is the clear cover on the front. The rear housing and insides are exactly the same for all Integras. They are interchangeable, BUT where would you find only the clear covers? Probably not anywhere.</TD></TR></TABLE>
Actually, after I had my accident (I rear ended some1) both of the housings of my headlights were cracked but the front clear parts were both perfect. It is possible but still gonna be hard as hell to find.
Old Oct 8, 2003 | 08:56 PM
  #31
Community Builder
Actually, after I had my accident (I rear ended some1) both of the housings of my headlights were cracked but the front clear parts were both perfect. It is possible but still gonna be hard as hell to find.</TD></TR></TABLE>
okay well if your front clear pieces are perfect, you might be able to find 94-97 lights for cheaper, heat them up and remove the clear covers, and then swap yours on there.
CaptinMcnut
May 3, 2006 12:46 AM
99jdem18L
Jan 31, 2006 06:56 PM
coreyciv95
May 17, 2005 02:50 PM
Dres
Aug 10, 2004 09:03 AM
FrostyDC4
Feb 25, 2003 10:47 PM
