98 Integra Starting Problems?
Old Jan 15, 2006 | 09:43 AM
sicx's Avatar
Default 98 Integra Starting Problems?
I could not find a solution for the problem I am having.
Basically when I go to start the car in the morning the car will click but will not turn over,
but if I hit the gas pedal once and then start, It fires right up.
Anybody think they know what the possible problem could be?
Any help is greatly appreciated, Thanks ahead!
Old Jan 15, 2006 | 10:05 AM
jdm_bones's Avatar
Default Re: 98 Integra Starting Problems? (allmotorTEG98)
Try checking your vaccume lines, It sounds like it's getting to much air and not enough fuel. How does it sound once it is on, is it revving crazy...
Old Jan 15, 2006 | 10:09 AM
sicx's Avatar
Default Re: 98 Integra Starting Problems? (jdm_bones)
No it runs fine after it first starts, The only time it does this is when the car is cold.
After I first start it up in the morning it wont do it again until I let it sit for 8 or so hours..
I am confused on why it is doing this..
Old Jan 15, 2006 | 10:18 AM
jdm_bones's Avatar
I see... What is the current Temp. of where you live, I ask this because it's still winter, and car are harder to start during this time of year. My next thing would be to check and clean the 3 sensors on you throttle body, then take soap water then run it over your vaccum hose with a brush while the car is on to see if it makes any bubbles, and around the area where it's suppose to seal, by the clamps...try it then get back at me....
Old Jan 15, 2006 | 10:26 AM
jdm_bones's Avatar
Another thing is to check your fuel see if there is any leaking around your fuel rail or fuel pressure regulator, because your problem can also be caused by low fuel pressure. also check you fuel filter when was the last time you cahnged it? Check for leaking around the filter as well..
Old Jan 15, 2006 | 11:04 PM
sicx's Avatar
Ok i just took my starter out and it smells like its burning up, going to take to shucks in morning for test.
Thanks for the tips so far!
tvdc2
Feb 13, 2017 05:19 PM
attack666
Feb 25, 2012 06:47 AM
